Interior Bulb Replacement Guide
ragingfish
Post by ragingfish » Sat Aug 28, 2004 2:31 am
List of all replacement bulb sizes for the interior of the vehicle.Roof-Mounted Map Light - MoonroofBulb Style = 1895Mirror-Mounted Map Lights - No MoonroofBulb Style = 192Center Dome LightBulb Style = 31mm x 10mm Festoon (8W)Rear Hatch AreaBulb Style = 31mm x 10mm Festoon (8W)
2009 PONTIAC G8
Mr. Poopypants
Re: Interior Bulb Replacement Guide (ragingfish)
Post by Mr. Poopypants » Sat Aug 28, 2004 3:58 am
SWEET! Thanks, this is what I have been looking for.
SheVibe
Re: Interior Bulb Replacement Guide (Mr. Poopypants)
Post by SheVibe » Tue Apr 04, 2006 1:25 pm
SWEET this make ordering leds super easy.thanks
sagekai
Post by sagekai » Sat Jan 13, 2007 2:08 am
Does anyone know how to pop the cover off of the roof mounted maplight (moonroof) to install a new bulb?
2003 Vibe Base- Silver Two-Tone, Injen CAI, Sony X-Plod Head Unit, 16" Voxx MG Rims, Tein S-Tech Lowering Springs, Painted Rear Brakes, OEM Exhaust Tip, Custom Rear Seat Back Covers MiVibe-ToolGuy's Fog Lamp Protectors, 111K Miles!
Re: Interior Bulb Replacement Guide (sagekai)
Post by ColonelPanic » Sat Jan 13, 2007 2:23 am
Remove the one philips head screw in the moonroof control / map light assembly. Then you can pry the entire piece off.
Neptune. Auto, Moon & Tunes, power package. 131k mi.
'13 Sonic LT - 1.4L ECOTEC turbo/6A. 97k mi.
'15 Escape SE - 1.6L EcoBoost, FWD. 47k mi. (hers)
Post by joatmon » Sat Jan 13, 2007 2:24 am
this one?http://forums.genvibe.com/zero...18486edit - CP beat me by a mnute
TheGeebs
Post by TheGeebs » Mon Dec 10, 2007 5:07 am
I can't find a part number for the bulbs behind the heater control knobs. My Temperature control is completely dark and the fan speed is dark on the right. I pulled the center instrument panel cover off and found a small bulb with a plastic base. No part number due to its size. Any ideas? Also I can't figure out how to remove the module that holds the vent/fan/temp controls. I found small plastic tabs to free the unit but something is holding it in from the left side so I can't reach behind to remove the bulb. Any suggestions would be most helpful.
ianvibe87
Post by ianvibe87 » Tue Apr 22, 2008 8:54 am
What would the size of bulb for the shifter? The bulbs that light up the D-for drive. Thanks
kevera
Re: Interior Bulb Replacement Guide (ianvibe87)
Post by kevera » Tue Apr 22, 2008 9:59 am
Quote, originally posted by ianvibe87 »What would the size of bulb for the shifter? The bulbs that light up the D-for drive. ThanksSylvania Part is a #74 bulb
ianvibe87
Re: Interior Bulb Replacement Guide (kevera)
Post by ianvibe87 » Fri May 23, 2008 5:23 am
Has anyone tried to replace the bulb that lights up the shifter letters? i can't figure it out
Wolfman213
Post by Wolfman213 » Sat Mar 21, 2009 9:06 am
The bulbs behind the HVAC controls are a NEO4, as listed on http://superbrightleds.com/instrument.html, as well as the bulb that lights up A/C and Recirc (the words not the activation as those are soldered in and pretty much unnaccesible.) The hazard light and the rear defrost (both indicator and picture) are NEO3 bulbs. Be very careful when replacing them as there is no wiring harness for them. They simply twist in and out of the particular hole and have contacts that get wedged between the base and the HVAC controls.**If replacing with LEDs** When relpacing these bulbs with LEDs, it is best to mark one side of the base. This will help you if you put the bulb in backwards are they are polarized.Also to add to kevera's reply, it's a #74 wedge. They do make #74 bayonet (round) as well so I figured I'd throw that in there.
A Psycho Martyr
Post by A Psycho Martyr » Thu Jan 06, 2011 4:49 pm
Quote, originally posted by ragingfish »Center Dome LightBulb Style = 31mm x 10mm Festoon (8W)Rear Hatch AreaBulb Style = 31mm x 10mm Festoon (8W) So....what's the bulb number? Can't find measurements on sperbrightleds like he's listed here
Ant03vibe
Post by Ant03vibe » Wed Dec 27, 2017 11:18 am
Hi Vibers
The Vibe my son just purchased for his first car (oh yeah! :-)) is a 2003 Vibe with a sunroof. The map/reading light bulb is burnt. I went to replace it but the #1895 bulb has a 14v rating and the one in it only has a 12v rating (the metal casing state "Life12v10w-g" Any concerns with a 14volt? Or should the previous owner replaced it with a 14v bulb? Not sure what the original voltage should be.
thanks for your help!
Chad
Post by andrewclaus » Wed Dec 27, 2017 12:02 pm
Either will work. A given wattage lamp rated 14V will be dimmer than one rated 12V, but will probably last longer (less heat).
The 12V rating on auto electrics is a nominal rating. The actual battery voltage, fully charged, exceeds 13V, and the alternator often supplies greater than 14V. The 12V rating accounts for voltage drop over the circuit to the load.
Ant03vibe
Post by Ant03vibe » Wed Dec 27, 2017 12:11 pm
Many thanks!
Have safe and happy New Year!
Chad :D
