Owners Manual PDF
ullbergm
Owners Manual PDF
Post by ullbergm » Tue Oct 01, 2002 1:24 am
[updated NOV 05 2009 by nsimkins]2003 Vibe Owner's Manual2004 Vibe Owner's Manual2005 Vibe Owner's Manual2006 Vibe Owner's Manual2007 Vibe Owner's Manual2008 Vibe Owner's Manual2009 Vibe Owner's Manual2010 Vibe Owner's Manual2003 Vibe Navigation System Supplement2004 Vibe Navigation System Supplement2005 Vibe Navigation System Supplement2003 Pontiac Warranty and Owners Assistance Info2004 Pontiac Warranty and Owners Assistance Info2005 Pontiac Warranty and Owners Assistance Info2006 Pontiac Warranty and Owners Assistance Info2007 Pontiac Warranty Supplement2008 Pontiac Warranty and Owners Assistance InfoGetting to Know Your 2004 VibeGetting to Know Your 2005 VibeGetting to Know Your 2006 VibeGetting to Know Your 2007 VibeGetting to Know Your 2008 VibeGetting to Know Your 2009 Vibe* don't forget, Adobe Acrobat Reader is required to view these files.* thanks again joatmon!
Car: Two-tone Base Abyss, Moons and tunes, Power packageMods: 20% tint, Reflective Black GrafxWerks Overlays, German Hella Horns, Hardwired Valentine One, red interior dome lights, custom cargo floormat, police scanner, ham radio, cellphone kit and a bunch of antennas on topWishlist: Rubber floormats, million dollars
NSimkins
Global Moderator
Post by NSimkins » Thu Nov 05, 2009 12:49 am
Added 2010 Vibe Owners Manual. Thanks once again joatmon!
ad57
Re: Owners Manual PDF (ullbergm)
Post by ad57 » Wed Apr 11, 2012 11:51 am
Hi, would you be able to find me a PDF copy of the Haynes repair manual for my 2003 vibe?Does anyone have a link to this manual?Thank you!
jeffypieguy
Post by jeffypieguy » Mon Nov 16, 2015 9:49 am
Yes I would like that too please
sideshowalan
Post by sideshowalan » Mon Nov 16, 2015 11:14 am
Not a Haynes manual but I've referenced this at least a hundred times.
2003 Toyota Matrix Factory Service Manual.
http://madstyle1972.com/Repair/
2008 Pontiac Vibe
2008 Toyota Sienna XLE
jeffypieguy
Post by jeffypieguy » Thu Nov 19, 2015 9:28 am
Awesome thanks
PattyM
Post by PattyM » Fri Feb 01, 2019 12:09 pm
Any chance of getting a link to the technical manual for base 2004 Vibe? I am specifically looking for diagram(s) of the crankshaft position sensor and the wiring for the front and rear end lights. I am attempting to obtain a salvage title and the headlamp/brake inspection failed and it’s also throwing P0335 code. It starts and runs fine (has a New 1ZZFE engine with 1k miles. Once the car has warmed and is shut off then I try and restart it cranks fine, is getting fuel but won’t turn over. Already had the camshaft sensor replaced. Also replaced ignition coils and the spark plugs were new with the new engine. I’ve put so much $ into this poor car I’m in way too deep to stop, lol. I am not a mechanic, just an old woman trying to do what I can to make this car pass inspection! Was hit in a rear end collision (the back is smooshed but trunk still latches/opens fine.
Post by joatmon » Sat Feb 02, 2019 11:34 am
Patty,
The pontiac service manual seems to be only available in print, and its expensive. There is a softcopy of the Toyota Matrix service manual out there on the internet somewhere, and most of it applies to first gen Vibes. I know the HVAC is different between Vibes and Matrixes, and there are some differences in the headlight wiring too. I've attached the part about P0335, which will be the same for Vibe/Matrix I don't know if that will help. If you can't get the issues resolved, you might get better specific feedback if you start a new thread just about the issues
cip0335.pdf
P0335
(29.23 KiB) Downloaded 15 times
