Ignition wiring help
Riley93
Post by Riley93 » Wed Dec 12, 2018 11:20 pm
My 03 Pontiac vibe was recently stolen. Got it back but, I need help figuring out which wires go where. There's 6 wires that go to the ignition switch. I bought 2 toggles and a spring loaded switch for the starter, just need help with a wiring diagram or explanation on how to do it in general
SlammedNiss
Re: Ignition wiring help
Post by SlammedNiss » Thu Dec 13, 2018 1:45 am
No reason to post this in 3 separate threads.
Here are the wire colors for the ignition harness. You really should use 3 toggle switches (2x ignition, 1x accessory) and 1 momentary switch for the starter. But you can probably get away with putting the 2 ignition wires together on a single toggle. You won't need the keysense wire. If you have any questions, feel free to ask and I'll do my best to help. Lucky for you the 03's don't have any immobilizer to deal with.
2003 Matrix Xrs Automatic
Riley93
Post by Riley93 » Wed Dec 26, 2018 10:07 pm
Okay so I question if If all the wires are 'technically' necessary. I tested them, (thru trial and error, not with a multi meter) and wonder do I run the 3 switches I have off the main power wire, or do any of the other wires carry power? (From what I know or learned i just need 'acc'; 'on'; and 'start' to function?) A few wires seem to be uneccessary?
SlammedNiss
Post by SlammedNiss » Fri Dec 28, 2018 1:19 am
The only wires you need to start the vehicle will are the first 5 lines in the list. These will all be in the main ignition harness going up the steering column. You can run ign.1, ign.2, acces., and starter all from the large heavy gauge white and black wires.
The difference between ignition and accessory are as follows. When starting a car, accessory wires will only need to see 12v in the 'On' position of the key. Ignition wires will need to see 12v in BOTH 'On' and 'Start' position of the key.
Riley93
Post by Riley93 » Sat Jan 05, 2019 9:20 pm
Is there any way you can specifically tell me how to wire this up. I'm just a kid trying to start my car.. I'd attach pictures but it wont let me. Please help. I believe I have designed a "harness' that'll work, but the first few trials blew a few fuses
Riley93
Post by Riley93 » Sat Jan 05, 2019 11:17 pm
I've ran the black 12v constant to the 2 toggle switches (black and yellow/ignition 2 and blue and red/accessory) and obviously the starter. And everything works as if you would turn a key (acc, on, start) but it wont start and it should. The only wires that are not hooked up are ignition 1 (black and white) and a white wire. Obviously ignition 1 sounds important, and when I give it juice, it sounds like a relay switch goes off.. I dont want to damage the car further. Do I just wire ignition 1 into one of the 2 toggles I have going on? And what is the purpose of this white wire? (So confused without a multimeter, tired of blowing fuses) (please help)
SlammedNiss
Post by SlammedNiss » Sat Jan 05, 2019 11:41 pm
Can you not just reattach the wires to each other where they were cut?
If not...
When the wires were cut, you ended up with a car side, and a key side. You'll only be using the car side wires at this point. You'll take the heavy gauge white (12v+) wire, and use it on the Starter toggle and the Accessory toggle. Take the other side of the starter toggle and attach the red (starter) wire. Take the other side the accessory toggle and attach the blue/red (accessory) wire. Take the heavy gauge black (12v+) wire and attach it to both Ignition #1 and Ignition #2 toggles. Take the other side of ignition #1 toggle and attach the black/white (ign.#1) wire. Take the other side of ignition #2 toggle and attach the black/yellow (ign.#2) wire.
If you don't have separate toggle switches for each ignition wire, then connect both black/white and the black/yellow together.
After everything is connected, to start the car, you'll need to turn on both ignition toggles, then use the starter toggle until the car starts. The accessory toggle only needs to be switched on after the car is running. However, the accessory toggle isn't actually necessary to make the vehicle run, but controls the radio and other creature comforts. Turn all off when you wish to turn the car off.
Keep in mind there are other wires running up the steering column. Including headlight, parking light, cruise control, horn, among others. This will only start the car and allow it to run. You will also still need the key in the keyhole or else your steering will lock up.
Good luck, and lemme know if you have any other questions.
Riley93
Post by Riley93 » Sun Jan 06, 2019 1:44 am
It's more of a someone jammed a screwdriver in my ignition and I'm trying to make it less stealable situation.. the whole ignition was pounded out and I have to use the cylinder tumbler thing itself to start my car.its ridiculous.i figured using the harness thing that goes to the ignition, and some switches (and of course hidden "killswitches") would make it harder to steal. I just haven't quite figured it out. I have 2 toggles and a spring loaded for the starter. I believe its wired right but it eont exactly start because I left out the white wire and the ignition 1 wire (black and white).. I theorize just hook ignition 1 up with the blue and red wire? (Which makes my radio work) also as said before when I give the wire in question (ignition 1) power, I can hear a relay trigger, which us why I theorize it should be hooked to my first toggle switch with my radio (accessories)
Riley93
Post by Riley93 » Sun Jan 06, 2019 1:51 am
I think I understand a little better. Are you saying I need a 3rd toggle?
Bookworm
Post by Bookworm » Sun Jan 06, 2019 2:47 am
Wouldn't it be easier to just hit up a salvage yard and see if one of the vibes still has a key available, and then just abscond with the entire ignition section? If you then want to make it harder to steal, just put a stack of toggle switches across the dash board, and label them things like "Fuse 1" "Ignition 1" "Pre-Ignition" "Starter" "Radio" "Windshield Wiper" "Brake Lights" "Fog Lamp" "Rear Defroster" "Weasel Wash" "Trunk Monkey"
First I've even heard of someone stealing a Vibe. I've had mine broken into twice - once they stole stuff, the other they just smashed the drivers side windows (front and back), and stole nothing.
In any case, what'll happen is that someone will sit down behind the wheel, and not have a clue as to how to start the car - even though you just need the key.
Riley93
Post by Riley93 » Sun Jan 06, 2019 11:29 am
I live in flint, Michigan. People steal water here and hahaha that's funny and a good idea. I think I just about got it now I'll lyk. Thanks for all your help
SlammedNiss
Post by SlammedNiss » Sun Jan 06, 2019 12:11 pm
I would recommend it honestly. If those 2 wires were meant to be tied together, they wouldnt be separate in the first place. Besides that, I don't know how much power you'll be drawing through the toggles, and you take the chance of melting them if you put thru too many amps.
Bookworm
Post by Bookworm » Sun Jan 06, 2019 2:04 pm
I've thought about putting a knife switch in for the starter relay.
