Gasoline vs E85
Vulcan05
Gasoline vs E85
Post by Vulcan05 » Wed Apr 17, 2013 9:24 am
Interesting test results. It actually COSTS MORE to run the "cheaper" ethanol.
http://www.edmunds.com/fuel-economy/e85 ... 96&msite=w" onclick="window.open(this.href);return false;
2010 Vibe. Moon roof, Monsoon, 2.4 engine, 5 speed auto, cruise, dark gray.
Old Tele man
Re: Gasoline vs E85
Post by Old Tele man » Wed Apr 17, 2013 1:10 pm
...but, it's MORE costly in the end as the excessive alcohol eventually "eats" the fuel system up.
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
Barton
Re: Gasoline vs E85
Post by Barton » Thu Feb 20, 2014 4:32 pm
Not to start anything but a lot of people don't really do there research on e 85. How did they fill the tank and come up with different gallons on each fill. Flex fuel vehicles are not designed to run e 85 optimally they just run it but have to run straight gas as well there for they don't run higher compression. One thing to consider e 85 is 105 to 108 octane, do the math against premium. Apples to apples, e 95 is better suited for guys performance orientated or for a engine built to only burn it.
I have seen plenty of articles done correctly showing e 85 as the better fuel because it was done correctly not by sulking the gass out. Keep in mind that the tahoe senses the percentage of alcohol in the tank it would need to be dropped and cleaned out to be an accurate test.
E 85 eats o rings because the card people choose to run it on aren't designed to run on it and they don't replace key components.
I have a 65 galaxie that I intend on changing to e 85 for several reasons
1 it's American fuel for my American car
2 I would pick up close to 20 horse on it
3 it burns cleaner
Dollar for dollar horse for horse you can't buy a gain in power that cheap any other way.
Please do your research and then make a decision, Edmunds is not a good source. I agree that a flex fuel vehicle will not utilize it the way it should be but look at the guys boosting engines, look at the cities where they have changed squad cars to e 85 and came back and said it only took 20k miles to break even keep in mind that squad cars idle for a lot of hours.
Vulcan05
Re: Gasoline vs E85
Post by Vulcan05 » Thu Feb 20, 2014 5:42 pm
"sulking the gass out"
Wait, what, huh?!?!?!?!?
I read your post 3 or 4 times and can't make heads or tails of it.
Probably just me.
Barton
Re: Gasoline vs E85
Post by Barton » Thu Feb 20, 2014 6:25 pm
Corey Gonzales put the Tahoe on a lift, disconnected the fuel hose and siphoned the gas out
Raven
Re: Gasoline vs E85
Post by Raven » Thu Feb 20, 2014 6:28 pm
And don't forget, if we use enough E85 we can use up all the corn and starve to death. Dead people don't drive cars so it's good for the planet to use E85.
Barton
Re: Gasoline vs E85
Post by Barton » Thu Feb 20, 2014 6:28 pm
Sorry I must have fat fingured it my phone likes to auto correct for me :oops:
Salsa Guy
Re: Gasoline vs E85
Post by Salsa Guy » Thu Feb 20, 2014 7:37 pm
E85 is a mistake. No savings and No better for the Environment. It's a total fail!
Vulcan05
Re: Gasoline vs E85
Post by Vulcan05 » Fri Feb 21, 2014 9:39 am
Salsa Guy wrote:E85 is a mistake. No savings and No better for the Environment. It's a total fail!
Short, to the point and correct.
Barton
Re: Gasoline vs E85
Post by Barton » Fri Feb 21, 2014 7:34 pm
So because it sucks in a flex fuel car it's a bad idea?
That's like saying diesel and propane suck in a gas engine, point being flex fuel cars are not designed correctly to take full advantage of e 85.
You need to think of it as a clean burning race fuel or cheap race fuel.
Re: Gasoline vs E85
Post by star_deceiver » Fri Feb 21, 2014 10:16 pm
There are places in the US where it is more cost effective to run E85, even with the poor mileage. For the big GM Trucks and SUV's it becomes more cost effective when E85 is about 30% cheaper than regular gas.
I'd test this out myself but there are only 2 E85 stations in all of Canada.... Both somewhere near Toronto...
2019 Ram 3500 4x4 CCSB srw 8HP75
hotbug1776
Re: Gasoline vs E85
Post by hotbug1776 » Mon Mar 03, 2014 5:42 am
I just did an essay on this very topic, and e85 is a horrible idea. We subsidize the corn growers/e-85 producers through taxes (you pay them to make it even if you don't use it). Then, around 40% of our feed corn goes to producing the ethanol, raising the cost to feed our livestock, in turn raising the cost of food. Therefore, you pay more for ethanol even if you never use a drop of it.
Pure gasoline, pulled from domestic wells, increases tax revenue through jobs, local businesses, and refinery growth. We now produce more oil and export to other countries more than we import.
Finally, with cars being so darn efficient, the fuel blenders cannot reach the mandated usage requirements and are now pushing to make e15 and higher the market standard, even though car manufacturers state that higher than e10 on non flex-fuel vehicles is damaging.
Raven
Re: Gasoline vs E85
Post by Raven » Mon Mar 03, 2014 7:02 am
Not to mention that it actually uses more energy to produce E85 than you get when you burn it in an internal combustion engine. This is after you factor in farm costs(tractor burning diesel), transportation (truck burning diesel), processing and transportation again to the pumps (truck burning diesel).
vit
Re: Gasoline vs E85
Post by vit » Mon Mar 03, 2014 11:45 am
Here is another kick to the balls: we are having high prices and low supply of propane that is used to heat homes in rural areas this winter - one of the coldest winters in a long time. Partly to blame was the high use of propane last fall to dry corn...
Raven
Re: Gasoline vs E85
Post by Raven » Mon Mar 03, 2014 1:18 pm
^^^Truth
Chiadog
Re: Gasoline vs E85
Post by Chiadog » Mon Mar 03, 2014 6:58 pm
E85 is your Congressman's Sloppy Wet kiss for monsanto and big farm interests! :x
Vulcan05
Re: Gasoline vs E85
Post by Vulcan05 » Tue Mar 04, 2014 3:14 pm
Chiadog wrote:E85 is your Congressman's Sloppy Wet kiss for monsanto and big farm interests! :x
Google Congressman Charles Grassley R-IA and EWG Farm Subsidy Database. Chuckie, his son Robin and grandson Pat (an Iowa state representative being groomed for grandpa's Washington job) have taken over a Million Dollars from the government. Chuckie HATES government hand outs. Well, not ALL of them.
Re: Gasoline vs E85
Post by lannvouivre » Sun Sep 18, 2016 2:42 pm
Bumping this topic to throw in some info via Ford.
Stoichiometric air/fuel mixture for pure gasoline: 14.7 units air : 1 unit of fuel
Stoichiometric air/fuel mix for E85: 9.8 units air : 1 unit fuel
Upsides of ethanol: reduced emissions, requires less air (LOL because that's the limiting reagent), combusts better and thus burns more cleanly, creates more power (yes, this is straight from Ford's training program), has an octane of about 96 in E85, can be used to raise octane level more cheaply.
Downsides to E85: requires special materials that resist ethanol, is less efficient than gas due to the 9.8:1 ratio, can cost more, subsidizing corn is stupid.
Vulcan05
Re: Gasoline vs E85
Post by Vulcan05 » Sun Sep 18, 2016 2:56 pm
"creates more power"?!?!?!?!?!?!?!?!?!?!
Alcohol has FEWER btu's per volume than gasoline.
Ford is saying that 3 firecrackers have more power than 3 sticks of dynamite.
A brain damaged store mannequin would know better than that.
Re: Gasoline vs E85
Post by lannvouivre » Sun Sep 18, 2016 3:16 pm
"The air-fuel ratio (9.8:1) required by ethanol means that while each molecule contains less heat, there are more vapor molecules.
This chemical difference produces slightly more power for each stroke of the piston than with unleaded gasoline.
However, due to the lower energy density of ethanol, vehicles running on ethanol get fewer miles per gallon than vehicles operating on unleaded gasoline."
Vulcan05
Re: Gasoline vs E85
Post by Vulcan05 » Mon Sep 19, 2016 7:31 am
lannvouivre wrote:"The air-fuel ratio (9.8:1) required by ethanol means that while each molecule contains less heat, there are more vapor molecules.
"more power for each stroke" but "fewer miles per gallon ".
I think you have been mixing alcohol with what it was intended to be mixed with, water, Coke or 7-Up.
Re: Gasoline vs E85
Post by lannvouivre » Wed Sep 28, 2016 11:56 am
Just because I accept that Ford probably knows what they're talking about?
E85 uses 9.8 parts air to 1 part fuel, while pure gas uses 17.4 parts air to 1 part fuel. That's why you have to use more fuel.
Also, heat value doesn't necessarily translate to power. I'm guessing they say it produces more power because it cools the intake charge better and resists detonation much better than pure gas, so a modern engine can advance timing further. ( http://www.speedhunters.com/2015/04/eve ... t-ethanol/ )
Of course, if you are confident that you can explain why Ford is wrong, I would be happy to read your thoughts.
jake75
Re: Gasoline vs E85
Post by jake75 » Mon Oct 24, 2016 7:00 pm
Mandated ethanol usage means most gasoline will have 10% ethanol - It's all feel good politics. Most of us cannot even find 100% gasoline. Next thing you know the govt will mandate a certain amount of corn oil to be added to butter - and then let them still call it "butter". Then they will be adding soy protein to milk and still call it milk. EPA mpg numbers are based on 100% gasoline but you can't buy it? How crazy is that? Just give the damn corn farmers some money and let the rest of us have the freedom to buy the gasoline we want.
Vulcan05
Re: Gasoline vs E85
Post by Vulcan05 » Tue Oct 25, 2016 12:49 pm
jake75 wrote:Mandated ethanol usage means most gasoline will have 10% ethanol - It's all feel good politics. Most of us cannot even find 100% gasoline. Next thing you know the govt will mandate a certain amount of corn oil to be added to butter - and then let them still call it "butter". Then they will be adding soy protein to milk and still call it milk. EPA mpg numbers are based on 100% gasoline but you can't buy it? How crazy is that? Just give the damn corn farmers some money and let the rest of us have the freedom to buy the gasoline we want.
Check this out:
https://farm.ewg.org/addrsearch.php?s=y ... =&stab2=AL
Robin Grassley is Senator Charles "Chuck" Grassley's son. Pat is his nephew. Pat is also in the Iowa legislature, being groomed to be appointed to replace Chuck by Governer Bumsted when Chuck dies.
