How to unclog rear passenger-side drain for sunroof(2003 Vibe)?
epcIII
Post by epcIII » Sat Oct 28, 2006 12:10 pm
Hi, first time posting--love the site, been very helpful.The front passenger side drain for my sunroof was clogged and I blew it out with a compressor, but the back one is clogged too(at least I think, when I parked on a hill, poured water down the inside side of the sunroof, no water came out underneath the car, but down the c-pillar(?) instead). I can't see where the drain is back there. Can you see it without taking the sunroof apart? Any suggestions would be appreciated--thank you.
joholste
Re: How to unclog rear passenger-side drain for sunroof(2003 Vibe)? (epcIII)
Post by joholste » Sat Oct 28, 2006 12:11 pm
honestly try a dilluted drano
epcIII
Re: How to unclog rear passenger-side drain for sunroof(2003 Vibe)? (joholste)
Post by epcIII » Sat Oct 28, 2006 12:22 pm
Wish that would work.... lol.
kostby
Post by kostby » Sat Oct 28, 2006 1:02 pm
You need to drop the headliner. I have two pics, one of the sunroof with the headliner dropped, and another of the tube. It's a blue transparent plastic tube that runs down the roof pillar behind the rear passenger door. Ragingfish dropped the headliner in his Vibe 'Emily' to install a GPS or satellite radio antenna at GenVibe in 2005. This is not a great shot of the sunroof rear drain. It's on the far side, above the onlooker's head. Sorry, but it's the only one I have.This shows the drain tube going down the rear window 'C' pillarMany GenVibe members took the opportunity to 'endorse' Emily's headliner. Kari and ColonelPanic are signing-in here!
My 2003 Vibe Base Auto 2-tone Salsa "SalsaWagon" was built in May 2002. I acquired it in Feb 2004/Traded it in on a 2016 Honda HR-V in Feb 2018
I'm '@facebookie' on Twitter. No, actually I STILL don't have a facebook account.
epcIII
Post by epcIII » Sat Oct 28, 2006 1:48 pm
Thanks kostby, I'll have to drop the headliner this weekend(if I can figure it out! lol). Thanks for the pics too!
scherry2
Post by scherry2 » Sat Oct 28, 2006 8:27 pm
it sounds like the hose might have come off the sunroof. but Kostby explained it best.
Re: (epcIII)
Post by joatmon » Sat Oct 28, 2006 8:39 pm
you could look under the back end of the car to see where the hoses come out and blow them out from that end
epcIII
Re: (joatmon)
Post by epcIII » Fri Feb 29, 2008 8:27 am
Sorry I haven't posted my fix till now. After taking off the rear passenger side plastic panel (the one on the side of the car below the very back window which the dreainage tube is behind), I could see that the blue drain tube was totally kinked and stopping any water from draining. I taped it up so it wouldn't bend so much at put it back in place and voila! it drains just fine now. Thanks everybody!
Re: (epcIII)
Post by joatmon » Fri Feb 29, 2008 9:30 am
nice, and welcome back
waveresponder
Re: (kostby)
Post by waveresponder » Fri Feb 29, 2008 11:22 am
Quote, originally posted by kostby »Many GenVibe members took the opportunity to 'endorse' Emily's headliner. Kari and ColonelPanic are signing-in here!hahhahahah...darnit i missed my opportunity to "endorse"...and yah kinks are quickly fixed with tape! ..and im positive im not the only one that's used tape to fix kinks in oxygen tubing and iv lines in the back of the ambulance if we dont have the time or patience to replace them during transport......and yessss Welcome Back! Please post more...you know you'd like to! ....dont forget to check out the 2008 North American Vibe Rally if you dont know about it already its in my signature...its happening in YOUR state!
epcIII
Post by epcIII » Fri Sep 18, 2009 2:21 pm
Ok, so old post, but I finally took a picture of where it was kinked in case it happens to someone else:This is the approximate path of the drainage hose under the cladding: And here's where it was kinked (which I fixed with duck tape and a piece of wood):
scherry2
Post by scherry2 » Sat Sep 19, 2009 1:22 am
regular Mcgyver you are
Jammin81
Post by Jammin81 » Fri Jan 17, 2020 6:54 am
Sorry to bump this post (going back to 09!) but I need some help!?
Where do the back drainage pipes exit the car? I removed the back wheels and even the plastic panels (back and in front of the rear wheels) but couldn’t see where the pipes exited the car.
My plan was to snake the tubes from the bottom as I can get access to the back holes from the sun roof?!
If anyone knows a way I would be happy to hear and thanks in advance
Post by zbyers » Mon Jan 20, 2020 4:32 am
Jammin, I took these two pics showing where the rear sunroof drains exit.. Turns out it's basically at the back of the car. This is the passenger side drain... I presume the drivers side is simliar.
This shows where it exacts near the rear tail light.
Sunroof Drain Exit-min.jpg (658.55 KiB) Viewed 319 times
This shows where it comes down the back side of the c-pillar
Sunroof Drain C Pillar-min.jpg (690.46 KiB) Viewed 319 times
'74 Thing, '79 El Camino, '83 VW Vanagon DoKa '91 Vanagon
(2) '03 Bases, '04 GT, '04 AWD, '06 AWD, '07 Base, '17 Frontier CCLB
Jammin81
Post by Jammin81 » Thu Jan 23, 2020 2:29 pm
THANKS so much for taking the time to post those pictures
A+++ and appreciation.
I know that can’t be the trouble now as it’s only the front driver side that’s wet.
I’m so sad that I can’t figure it out. I have snaked the front two holes and cleared the drainage Chanel under the plastic housing beneath the windscreen.
Somehow water is still making it in the front drivers side
Post by zbyers » Fri Jan 24, 2020 4:12 am
Next guess would be to check the windshield seal. If the glass has been replaced at all, it's possible they did a poor job installing the shield. If you also have some rust bubbles on the roof, it's possible that you've got some holes underneath it causing it to leak.
Jammin81
Post by Jammin81 » Sat Jan 25, 2020 12:50 pm
It’s pissing down here and sat there in the car watching and waiting. It can’t be a large amount as it wasn’t flooded like before.
I cleared all four sunroof drains and sealed the door seals over again.
Do you know if the doors have drainage channels at the bottom of the doors?
My next step after that is the windscreen. I already removed the wipers and cleared the Chanel under the windscreen .
Thanks for posting also.
Post by zbyers » Mon Jan 27, 2020 4:22 am
I've never looked, but i would presume there would be a drainage hole or two at the bottom of the doors.
Based on everything you've mentioned, I really do feel it would be the windshield causing your leak. If it's less, the issue was probably originally compounded by clogged sunroof drains since that's notorious for happening on all cars anywho.
Jammin81
Post by Jammin81 » Thu Jan 30, 2020 11:58 am
Thanks for your reply! I removed the front grill again and started to seriously clean the whole drain Chanel again. I noticed the left side drained 200% faster.
I snaked that drivers side Chanel and removed so much mud and leaves it was crazy.
How many drainage scuttles are there supposed to be? I only found ONE on the PASSENGER side? The little black plastic drain gutter under the windscreen - Is there supposed to be two drainage scuttles? One passenger and one drivers side? I only see the passenger side Chanel?
Please help or let me know.
Thanks AGAIN in advance and any help is appreciated!!!
Post by zbyers » Fri Jan 31, 2020 4:12 am
Now it's beyond me as I've never messed with those ones. :D
Jammin81
Post by Jammin81 » Mon Feb 03, 2020 1:25 pm
Anyone else know how many drainage scuttles there are? Doesn’t make sense that there is only one on the passenger side.
Also doesn’t make sense how I could be missing one?!
