Valve Cover Gasket and swaping Heating Mirror from
cq358
Post by cq358 »
Went to local junkyard since it is nice weather, for me it is a candy store. got a pair of heated mirror from CDN matrix with 4 wires into the plug. I hope it is a simple plug and play. I will let you folks posted.
Trix Mirror and 09 Mzd 6 light housing
Trix mirror.jpg (155.46 KiB) Viewed 147424 times
When you go to cash and pull wrecker, in addition to your handy tool, bring a bottle of liquid wrench with you, learnt the hard way with removing the dumb ford engineered mazda 6. they use 3 differ bolt sizes at the front and many of them are rusted..
Just replaced my valve cover gasket, Valve Cover Gasket Set Mahle VS50362 MADE IN JAPAN, and they are identical to factory one ( with notches so the gasket dont hang down when you placing your valve cover back ) and half the price.
At the yard
At the yard
coated with Rustoleum Gloss Clear non yellowing UV resistant
Polished Headlight.JPG (137.42 KiB) Viewed 147267 times
Re: Valve Cover Gasket and swaping Heating Mirror from
i do not believe the mirrors are plug and play. keep us posted though, i am curious.
cq358
Post by cq358 »
At the self serve wrecker yard has a 09 matrix and a 09 awd vibe. I bring the vibe mirror to the matrix mirror to match them up and they are identical. They both have the same round 4 pins connector. Vibe only has 3 wire and Matrix has 4 which come with the heated feature. I should had take picture of the wreck vibe which has 1 the pax door missing but they left the mirror there.I was in a rush of fighting a rusted bolt on my other task so I was short on time to really think clearly to snap all the necessary pictures. But I will open up my Door Panel as long as the weather cooperates.
cq358
Post by cq358 »
zbyers wrote: Mon Jun 10, 2019 3:13 am i do not believe the mirrors are plug and play. keep us posted though, i am curious.
Yes you are right. I took the door panel out..the other end only have 3 pin so it is missing the 4 th heater power...so it is basically have to run another wire from there to the defrost relay. I have taken a lot of photo ...
Colour Code2.jpg (45.74 KiB) Viewed 147376 times
cq358
Post by cq358 »
Actual vs diagram
Link below also talks about different Molex connectors toyota uses.. it appear the connectors can be different shape that dependent on the connectors ( 8 pins.. 10 pins, they can be different) so have to pay attention on sourcing parts
https://blog.machanon.net/2013/05/13/di ... Qgcw3rPy72
the factory came with a mysterious splice wire
Shouded Cable.jpg (167.24 KiB) Viewed 147355 times
Heated Schematic.jpg (104.5 KiB) Viewed 147373 times
Connectors matched picture
Showing wire colour (G , Light Green & yellow)
Actual Vibe Wires.jpg (149.77 KiB) Viewed 147374 times
Mirror Control Diagram
Mirror CTRL Diagram.jpg (73.91 KiB) Viewed 147374 times
cq358
Post by cq358 »
Neutral -ground wire
common ground.jpg (58.73 KiB) Viewed 147353 times
Reference website
https://www.tacomaworld.com/threads/hea ... vy.377840/
Also look at the common ground wire that terminated and bundled with my power mirror wires
Nice write-up ! ;)
2014 Silverado, 2004 Vibe GT
cq358
Post by cq358 »
Each connector per door
Door Main Connectors.jpg (96.71 KiB) Viewed 147313 times
tpollauf wrote: Thu Jun 13, 2019 11:22 pm Nice write-up ! ;)
Thanks Tpollauf !
NASA soldering standards
https://www.youtube.com/watch?v=O-ymw7d_nYo
Also confirmed from the HTR Mirror fuse that it does have 12V when enable rear defogger
door wire.jpg (92.4 KiB) Viewed 147313 times
cq358
Post by cq358 »
Journey of finding all the plugs in hope somehow they are somewhat pre wired......chances is getting slim
looking at the harness 82151 from the above diagram
HE2 plug(not IE2-correction) should be at the "burnt orange" colour electrical tape
One interesting observation, Toyota does know how to proper position their electrical wire away high humidity area(avoid condensation from the floor board..etc). All main power wire harness are routed across top of the dash behind pax air bag and radio areas. In theory you could find a flooded title and can be drivable for many years as long as the water line dont go pass the red circle area
IE2 Overivew.jpg (156.62 KiB) Viewed 147239 times
cq358
Post by cq358 »
cq358
Post by cq358 »
Close up
No Sky Blue wire, no pin nada..=(
next step has to find the "2M" terminal
