awd right front cv axle removal
sparky12
Post by sparky12 » Sun Aug 04, 2013 7:23 am
has any one had any experience removing the right front cv joint on an 05 awd vibe..it is not your average animal,,it has a large bearing on it in the end of the transaxle,,and stub shaft a ppears to be about a foot long,,gave it a couple good licks with a hammer ,,.and nothing happened,,any info appreciated
shermaner12
Re: awd right front cv axle removal
Post by shermaner12 » Wed Jun 13, 2018 5:52 am
Did you have any luck with this. Doing this this weekend. Watched a few videos, seems like you need to take the carrier bearing bracket off the engine in the process.
Let me know if you did this.
jolt
Post by jolt » Sat Jun 16, 2018 6:26 pm
Do you really think sparky12, with one post five years ago and has never posted since, is going to reply?
SeattleJeremy
Post by SeattleJeremy » Sat Jun 16, 2018 8:05 pm
shermaner12 wrote:Did you have any luck with this. Doing this this weekend. Watched a few videos, seems like you need to take the carrier bearing bracket off the engine in the process.
hi Shermaner12
Check out these videos. Hope this helps
https://www.youtube.com/watch?v=YEwSe4xjD4Q
https://www.youtube.com/watch?v=bzkywfOCVoU
06 Vibe Base - Mono Platinum - Manual
Post by zbyers » Wed Jun 20, 2018 3:18 am
jolt wrote:Do you really think sparky12, with one post five years ago and has never posted since, is going to reply?
Necro at it's finest.
Ruby- 03 Salsa, Ray[is]AWD- 04 Salsa AWD, Simon- 03 Silver "Faux by Four"
Raven- 03 Abyss GT, Neptune- 05 AWD, Robyn- 07 Stealth Gray Metallic, Mystic- 09 AWD
GenVibe on Facebook, Everything You Need To Know About Vibes, Great How-To Index
shermaner12
Post by shermaner12 » Wed Jun 20, 2018 7:57 am
Thanks for the links but I have seen those. Neither are how my vibe is set up. The 2005 AWD the bearing is actually housed inside of the transfer case. Same ring and bolt retainers but not in a seperate bracket. I managed to have a dealer pull it for the whopping price tag of $1000. And after seeing how much rust there was there was no way with out a lift and a 15# sledge i was ever going to get that out. Heres a photo. You can see just how much bigger the bearing is toward the outside.
SeattleJeremy
Post by SeattleJeremy » Fri Jun 29, 2018 8:23 pm
shermaner12 wrote:Heres a photo. You can see just how much bigger the bearing is toward the outside.
Wow, that's a weird setup. Thanks for posting a photo.
