I just replaced most of my brakes on my 2004 Vibe and there is one nagging issue that I cannot uncover. The rear drums make a thumping noise when I brake harder to come to a stop. If I slow more gradually, the brakes are quiet. In the rear I replaced the wheel cylinders, shoes, hardware and drums. Drums are Raybestos shoes Wagner. On the front I rebuilt the calipers and replaced pads and rotors. The brakes work well. No pulsation, no pulling. The rears are adjusted so the tires rotate freely, but the e-brake engages in about four to five clicks. If I do brake hard enough for the thumping/nocking noise to start it will match the wheel speed and pretty much continue until I come to a stop. I haven't been able to identify if it is coming from the left side, right side or both. I also really don't feel anything coming through the brake pedal.
Anybody have any ideas? I hate to leave it is as because it will be my daughter's car and when she drove it, it thumped every time she used the brakes
Not sure if it matters, but the car does have ABS. It doesn't make the typical ABS chatter noise when this happens and it continues all the way to a stop.
