There is no steering gear box that I can see to adjust loose steering?
I have a vibe 2007 fwd with the 1.8 engine and just replaced front and rear shocks and springs with kyb brand. I also replaced both front inner and outter tie rods and both front lower ball joints. Also about a year ago both front bearings have been replaced. And a front end alignement has just been done. And there is about 1 to 2 on a clock to about 10 to 11 before the wheels start to move.
Is there any adjustment under the drivers steering column that can help tighten up the steering slack?
There are no noises while driving and both wheels when off the ground seem tight and don't move.
Any help would be greatly appreciated. As for km's on the vehicle is around 400 000km to 450 000km. Motor runs like new. As we know the odometer locks at 299 999km and I Havent replaced that, just not worth it.
Regards,
Tim H.
