Hello! I'm troubleshooting a ghost knock sound when travelling on rough roads in my 2009 vibe Awd. It's coming from the drivers side and sounds exactly like a sway bar link end, which I've already replaced as a precaution.
Everything else is tight, no play in tie rods or ball joints. The shock tower bolts and centre nut are all tight. Only thing left is the strut mount I suppose. Is this possible? Do these things produce a knock when they're failing?
Thank you,
Ross
