mango02 wrote:When you lower a VIBE you screw up the GEOMETRY. When you install different aspect ratio tires or size you screw up the GEOMETRY. Has anyone experimented and raised a VIBE? There is one RALLY VIBE did he use stock springs? does anyone make anything for a VIBE to make it TOUGHER, STRONGER? Does Toyota TRD make anything for a MATRIX Corolla? Skid Pan like VW makes for the JETTA?
He is on stock suspension with a skidplate in front.
