celica front swaybar???
Bad Vibe
Post by Bad Vibe »
I came upon a free hotchkis front swaybar for a 7th gen (00) Celica GTSAny one know if theres a chance an this be made to fit my 03 Vibe GT?I read a post somewhere that celica rear sways fit awd ind. Rear susp no clue about front thoughIf not anyone have a celica and $60?
03 Vibe GT JDM MR-S 1ZZ-FED swapped w/C60 6 speed - Starting Part out! - 230k mi
90 Celica Alltrac Awd Turbo ST205 swap Red - sold... Buy more parts BC I'm Buying her back!
01 MR2 Spyder Vibe 2ZZ-GE w/ Jdm C65 LSD Trans swap -sold
06pvibe
Re: celica front swaybar??? (Bad Vibe)
Post by 06pvibe »
I wish I could answer your question, but I don't know for sure.Frankly, I usually worry more about upgrading the rear sway bar in any FWD car I have owned. That's what will help counteract the inherent understeer.In my Mazda3, for example, I have upgraded the rear bar from the OE 20mm bar twice while retaining the OE front bar. First to a 22mm adjustable bar set to full. And more recently to a 27mm Racing Beat solid bar. The car understeers so much less now and is more predictible.
keithvibe
Post by keithvibe »
The rear sway from the celica doesn't fit the AWD vibe or matrix (03-08)The front should be a direct bolt up.
mac99d
Re: celica front swaybar??? (keithvibe)
Post by mac99d »
Does it look like this.
Mac's Vibe.
