Bad rear brake line?
DopeVibeGT
Postby DopeVibeGT » Tue Feb 06, 2018 5:16 am
I replaced the rear calipers a little over a year ago. My rear drivers side seems to be dragging. I dont think it the caliper, since if I open the bleeder valve, the caliper piston pushes in. If I dont, the piston goes no where when trying to compress it. I've read about the inside of the hoses collapsing and acting like a check valve, not letting the fluid go back up toward the reservoir. Thoughts?
Pictures of my ride!!
'03 Vibe GT
My AED GA!
Work in progress
Re: Bad rear brake line?
Postby vibrologist » Tue Feb 06, 2018 7:50 am
That was my very first thought.
http://forums.genvibe.com/phpBB3/viewtopic.php?f=30&t=43476
jolt
Postby jolt » Wed Feb 07, 2018 11:33 am
Well, the rubber hose for the brake line would be the cheapest thing to try first. At the other end of the cost spectrum is the anti-lock brake controller has a sticking valve in it. Be sure to flush the system with new clean brake fluid when you replace the hose, that way the controller may free up and not hold back pressure on that line if that is the cause. If the new hose and fluid flush does not help then look at the anti-lock controller as a possible cause.
DopeVibeGT
Postby DopeVibeGT » Mon Mar 05, 2018 5:00 am
Ok, anyone know what size flare nut wrench to use on the flare nut to the rubber hose?
'03 Vibe GT
My AED GA!
Work in progress
DopeVibeGT
Postby DopeVibeGT » Fri Mar 09, 2018 6:58 am
Ok, turned out to be the caliper. I took the hose off and tried to compress the piston and it didnt move easily. It's covered under warranty, so Im happy. Just have to buy new pads and mostly likely a rotor.
'03 Vibe GT
My AED GA!
Work in progress
Return to “Handling, Suspension, & Brakes”
Who is online
Users browsing this forum: No registered users and 1 guest
