It's inside the fuel tank, attached to the fuel pump, which you can access through the port hole under the rear seat.
Its not in the maintenance schedule because its is not considered something that would normally need to be replaced over the lifetime of the car.
Are you having symptoms that lead you to suspect the fuel filter, or are you looking at it as general routine maintenance?
I have no idea which variant is appropriate. Looking at step 16 of the attached fuel pump procedure from the 03 matrix manual, I'm not sure you're looking at the right part, if its a choice between two and three tube versions. Maybe the whole fuel pump assembly, but the filter looks like a little bag in this doc
ZZvroom wrote: ↑Tue Sep 08, 2020 10:37 amI looked in the factory manual set and found no mention of it.
If you have the big two volume factory service manual from Helm, the procedure begins on page 6-655. Looks like it has the same pics as the attached matrix doc
