cthomasparr wrote:Sorry. I see you have a 2006 !!
I just looked at my vibe and I see there is lots of room in front of the A/C condenser and I can put it in that area and have lots of access from below. I may be missing a protective plastic cover. When I look down between the grill and condenser I see only my driveway. It appears that it might also fit between the radiator and condenser, but that looks tight and not the suggested install.
The one thing that looks like it might be a challenge is threading the clamps through the condenser. Not sure how easy it will be to put the plastic ties through the condenser without moving the radiator out of the way. Pulling the radiator out should be easy enough. I think if you remove the upper clamps, you can tilt it toward the firewall enough to get enough access to put in the ties.
When are you planning on installing yours?
Thanks to all that replied... cthomasparr -- I do have a 2006, and I have a Derale Series 8000 Plate and Fin. That was what Etrailer recommended for the Vibe.
I am wondering if I need the additional GM adapter fitting ? I don't think I need it after nosing under the hood tonight, but wanted to confirm with the group here?
Anyone that has used mounting brackets vs the zip tie arrangement through the rad fins?
Cheers
rtr
