Bright yellow fluid .... what is it?
poyota_apprentice
Post by poyota_apprentice » Sun Feb 13, 2011 12:37 pm
I have had this situation 2x now... 2004 AT Base 2WD.....I have had a situation where my car sat overnight and I started it in the morning. after it warmed up i backed out of the driveway and noticed a spot in the snow which was bright yellow?.... that was like 3 weeks ago. Then it did it again yesterday where it was parked and by the sidewalk. I dont see it when i park in the street or at work, but im perplexed as to what it is. oh and no I dont have a dog lol...... any ideas what fluid could possibly be bright yellow and leak from underneath the car?
Re: Bright yellow fluid .... what is it? (poyota_apprentice)
Post by KITT222 » Sun Feb 13, 2011 1:01 pm
That would be brake fluid. You might want to get that sorted out ASAP.
dcbridgwater
Re: Bright yellow fluid .... what is it? (KITT222)
Post by dcbridgwater » Sun Feb 13, 2011 7:20 pm
I too have seen that and yet to find out what it is.Have seen it on my 1999 Astro van and the 2006 VibeOn the van it was located in an area that would have no brake fluid.
2006 Neptune AWDSide & Curtain AirbagsABSPower Package
dayday
Post by dayday » Sun Feb 13, 2011 7:25 pm
It may be an aftermart brand of coolant. All the brake fluid I've used has been clear and turns brown with age.
'09 Vibe 2.4L 5sp
06pvibe
Post by 06pvibe » Sun Feb 13, 2011 8:52 pm
Sounds like your basic Prestone to me... though there might be a hint of green in there. Prestone has an iridescent look to it.I would check any hose clamps that may have come loose. Then check for any leaky hoses. The car is nearly 8 yrs old now and it might be time for some hose replacement.
beemerphile1
Post by beemerphile1 » Sun Feb 13, 2011 9:20 pm
I say antifreeze/coolant. Some of it is a fluorescent yellow/green color. I've never seen yellow brake fluid.
lovemyraffe
Re: (beemerphile1)
Post by lovemyraffe » Mon Feb 14, 2011 12:31 am
Sounds like antifreeze/coolant to me too.
wt2ga
Post by wt2ga » Mon Feb 14, 2011 2:07 am
jake75
Re: Bright yellow fluid .... what is it? (wt2ga)
Post by jake75 » Mon Feb 14, 2011 3:51 am
I remember that RainX windshield washer fluid I bought once was yellow.
zionzr2
Re: Bright yellow fluid .... what is it? (jake75)
Post by zionzr2 » Thu Feb 17, 2011 7:30 am
Quote, originally posted by jake75 »I remember that RainX windshield washer fluid I bought once was yellow. I use the RaniX washer fluid all the time and the stuff I get is Orange. I would suspect the coolant as well. might set a piece of card board under over night to see if you can more precisely i.d. the location of the leak.
jake75
Re: Bright yellow fluid .... what is it? (zionzr2)
Post by jake75 » Thu Feb 17, 2011 12:36 pm
Opps - I think my 68+ year old brain is not working - I think it was Prestone Brand washer fluid that was yellow. - not RainX.Just did a quick internet look - the Prestone is yellow.
