cptnsolo77 wrote:Replaced door glass window run. Very easy !.....however this strip of rubber cost me 60 bux ! The only reason I replaced it because Im getting my windows retinted and 2 places have recommended it being replaced, or it may ruin the tint. At least it was easy to do 8-)
I beleive this is a genvibe member. Very helpfull.
https://www.youtube.com/watch?v=bDuHwyKiOgo&t=34s
Yes, it is our own Derf. What happens if you read Derf in reverse?
cptnsolo77
Post by cptnsolo77 »
New wiper blades, rain x wiper fluid and a can of seafoam in the tank 8-) Going steady at 230K 8-)
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Last Saturday I did the 80,000 mile oil changes and quick interior details on both Vibes.
My Vibe on 04.03.18
My mom's Vibe on 04.04.18
cptnsolo77
Busy weekend ! Friday was a Bad battery, but that was fine. Saturday my radiator was leaking. Had a crack on the plastic tank. $130 bux at advance auto. Easy job except for those stupid OEM hose clamps...made new curse words removing them and trying to reuse. I ended up picking some worm gear clamps instead. Piece of cake afterwards. Everything turned out great in the end. Even replaced the lower radiator hose and hosed the AC condenser since i was there. Next chance I will replace the upper hose and tstat. Just needed to get her back on the road for monday :roll:
KingKrab65
Post by KingKrab65 »
Changed the wiper blades, front and back. Washed and waxed the Vibe too.
2003 Base Vibe
This past Wednesday (April 11th), was the 9th anniversary of bringing my Vibe home!
cptnsolo77
Fun repairs this time :lol: :lol: :lol: Replaced my 7 year old Polks with the new DB652 series in the front. Unfortunately the old ones were water damaged. Replaced both door runs, used one of those speaker baffles ( had to modify cause they kill the bass ) and repaired the door trim prior to install to ensure it doesnt happen again. Got my tunes back though !!! 8-) 8-) 8-)
SeattleJeremy
Post by SeattleJeremy »
Fresh air filter today. Boy, was that old one nasty. I had been replacing it every year or so, I think I went two years. Turns out it was one too many.
Turo'ing 15' BMW 328i Sport - Jet Black - Auto
Daily 19' Toyota Camry SE Hybrid - Galactic Aqua Mica - eCVT
MacGyver
Post by MacGyver »
Checked air filter. Last changed Apr 27 2017, still clean. Applied RainX to the windshield. Fixed a loose connector behind the airbag that was causing the steering wheel controls to flake out.
2009 Vibe Base
The plasti-dip has been flaking off the roof so it had to go. It's been such an ordeal trying to get it all removed so I've been working on it gradually for the last few weeks. FINALLY got all of it off today, exposing the failed clearcoat in all its glory once again.
Washed the car and broke out the DA for a coat of cleaner wax. Cleaned the interior up. Ol' car looks as good as it possibly can.
Changed the cabin air filter. I'm tempted to change the oil - it was last done back in August but I'm only 2600 mi into this OCI so I guess I'll hold off for a little while.
Image Image
ColonelPanic wrote: I'm tempted to change the oil - it was last done back in August but I'm only 2600 mi into this OCI so I guess I'll hold off for a little while.
What's the rush :lol: My vibe has only had three oil changes in it's 9 year life so far (still sitting at 25k miles) :o Got yelled at by the oil analysis people when I sent in oil from my 1992 F-150 after a 7 year oil change interval and approximately 9000 miles during that time ( it finally just turned over 60k miles). Surprisingly there was not any major engine damage done. Was advised to change oil every two years regardless on the mileage.
2014 Silverado, 2004 Vibe GT
tpollauf wrote:...Was advised to change oil every two years regardless on the mileage.
How about tires? Someone I know said tires have a limited safe life span. I heard four years.
My driving habits changed a few years ago and I only drive a few thousand per year. I change oil every year, at least.
I bought a set of used tires fro my son's Hyundai Sonata. I did not check the production date imprinted on them. it's an oval with 4 digits showing week and year. I.e. 2508 = 25th week of 2008 or summer 2008. I just looked at them when I swapped from the winter tires. They are 10 years old! I've seen some minor cracking in the sidewalls. They do hold air, are nicely balanced and have good tread except for one of them. Of course the grip is now reduced but still good to very good. You rarely ever go to the limit anyway. I am sure winter performance would suck, but we have dedicated wither tires anyway.
In my opinion they are due, so I am looking for a good deal. Is it urgent ? No. Not for our way of using the car. It's a judgement call.
What happens in year 4? If you have a tire with a 90000 mile warranty and the average yearly mileage in the US is about 12000 shouldn't you get 7 to 8 years out of them?
In my opinion the 4 year limit is arbitrary and probably put out there by someone who has an interest in selling more tires.
Scotty Kilmer made a video referring to tires: https://youtu.be/6PM3M6lWGHM
Finally had time to get the 18s put back on our Vibes this morning. I also gave my mom's Vibe a much needed bath. I wanted to do mine too, but it's going to rain tomorrow :(.
I just removed automatic A/C from the defrost control in my '07. I unplugged the two-wire connector at the back of the heater control. It's easy with the radio out, takes about 1/2 hour.
I live in a dry, temperate climate, where I seldom use A/C. Once in a while I get a carload of wet skiers on a cold day, and I need the A/C then. Most conditions, heat only works just fine. I also know to manually turn the A/C on once in a while to circulate the refrigerant. (I'm such a efficiency wienie, I do that on long mountain grade descents, as an engine brake of sorts.)
Replaced the hatch struts on both Vibes today for the first time in the just over 9 years we've had them.
I ordered them from GMPartsCenter.net for $18.42 a piece. In case anyone needs or wants the part numbers...
09-10 Vibe right hatch strut: #19184244
09-10 Vibe left hatch strut: #19184245
I replaced the factory radio with an inexpensive Boss brand from Crutchfield today. Total cost was $70. It seems to work fine, playing the radio, CDs, and audiobooks via Bluetooth. It's the best-looking after-market installation I've ever done.
The Crutchfield free installation kit worked out alright, but the instructions with the mounting bracket/bezel were pretty much nil. I was just lucky to figure out there was a removable insert behind which the radio case mounted. I was about to do some cutting. I had to cut some unneeded mounting brackets off, too, but that was self-explanatory. Otherwise it fit great and went together easily. Total time was less than an hour.
I'm happy to see the last of the broken factory radio. The clock didn't even work on it any more, with most of the display lights burned out. Neither the tuner nor volume knobs worked reliably or consistently. It was not worth trying to fix it.
We drove the VIbe up to the Continental Divide this morning with our bicycles, and cycled the Bakerville-Loveland Trail (BLT). The two road bikes fit nicely in the cargo area with front wheels off. We also drove to a trailhead on a rough road above Georgetown and did a little hiking in an historic mining area. Front wheel drive was all that was needed, and clearance was just high enough. It was a nice two-sport day with the Vibe.
ehoff121
Post by ehoff121 »
Finally got around to changing out the Valve Cover gasket. While I had everything apart, I replaced the air filter, changed the spark plugs a little early, and took care of a stripped screw on the IACV (then cleaned it out and changed the IACV gasket!). Finished with a Simple Green of the engine compartment.
Have to wait until 5:00 PM EDT tomorrow to start her up- the two dabs of RTV on the valve cover need 24 hours to cure...
EDIT 6/17: She started up just fine and when she warmed up, the idle was pretty steady at 800 rpm, which is a bit higher than in Drive w/ brake on (750 +/- 25 rpm) and before the gasket change. Will report back if any other noticeable differences...
EDIT 6/22: Idle was still getting into the low/mid 600's after reaching operating temp when at a stop in Drive. Got a P0420 code while driving through a T-storm earlier in the week after the valve cover gasket change- was getting them prior to the change, so was hoping that would fix it. Ordered a PCV valve and installed it. Idle seems a bit better.
'Twas a few weeks ago, but removing the valve cover, timing cover, and replaced those gaskets along with the crank seal, resealed the oil pan with FIPG, and a fresh oil change on my 03 GT. Also replaced the water pump, serpentine belt, and lift bolts while I was at it. At 267k she is no longer leaking any fluids and is running like a champ.
The 07 needs a big dent pulled from an accident over the winter where someone ran a stop sign and hit us. Hasn't been a major concern. Hopefully after my wedding in a few weeks I can take care of that.
I just drove 1000 miles in my '07, from Denver to Albuquerque, with a loop through Durango, CO back to Denver. Very nice ride on the new rear shocks and I enjoyed listening to audiobooks on my iPhone via the new stereo. (Those projects cost me $70 each. I'm pleased with the car's economy so far.) I brought my road bike, and didn't have to take a wheel off to stow it in back.
First two legs were in headwinds and it was hot so I used the A/C (which I just recharged), and I got 36+ mpg. Those legs were also on four lane, 70 to 75 mph limited-access highway. Last leg through the mountains, mostly two-lane, with a good tailwind, I got 45+ mpg. Again, fairly economical.
One little mech problem in a heavy monsoon rain storm: I switched the wipers on high and one of them jumped out of position. The wiper was very loose on the shaft. I removed it to check the splines and they look okay, so I tightened the nut and all seems well. It's a tapered spline arrangement I hadn't seen before, not that I have vast experience with wiper shafts.
I think the new shocks gave some lift in the rear. I parked next to another Vibe once and could see the difference. I'm considering doing the fronts now, though the ride seems fine.
Yesterday my Vibe turned over 83,000 miles!
Today I received and installed a Diode Dynamics SmartTap CF18 LED flasher module. It's a really neat little toy!
MrManager
Post by MrManager »
Well it finally happened. First the rust on the exhaust started on the pipe behind the muffler, causing it to be a little louder. Then the rust started to make a whole after the resonator, making the car even louder. Now it finally severed after the resonator completely.
It's a shame the only exhaust I can find is the Magnaflow one. That is way too expensive. I'm thinking about having a shop just fabricate one.
2009 Vibe GT
zbyers wrote:'Hopefully after my wedding in a few weeks I can take care of that.
How was the wedding, and Congratulations!
KingKrab65
MrManager wrote:Well it finally happened. First the rust on the exhaust started on the pipe behind the muffler, causing it to be a little louder. Then the rust started to make a whole after the resonator, making the car even louder. Now it finally severed after the resonator completely.
RockAuto has all the pieces to make an exhaust if you are looking for a stock-like replacement. Or you canjust do the part of the exhaust that is busted. https://www.rockauto.com/en/catalog/pon ... &+emission
2003 Base Vibe
MrManager
Post by MrManager »
I see the muffler and tail pipe, and the part for the O2 sensor, but I don't see the intermediate pipe? after the resonator
2009 Vibe GT
Today I replaced the cheap radio I bought from Crutchfield. It would lose power randomly, hopefully the new one is better. I don't expect too much for $70. But Crutchfield sure is excellent on warranty service, within 60 days.
I was a little miffed the rear connector changed in those 60 days, so I had to spend an extra ten minutes and rewire it.
Still pleased with the Vibe, 8000 miles driven in the 9 months we've had it. Half those miles have been on vacation road trips. No issues have come up at all, just maintenance stuff.
bigdoug
Post by bigdoug »
Wow, haven't posted in this forum in a while. Didn't do much to my car besides regular maintenance during the winter, when late spring came I started fixing things on it again. Because summer is almost over I'm trying to finish doing all the cosmetic stuff before it gets cold.
joatmon wrote:Found (and fixed) the source of coolant loss in my 03 trix
Glad autozone stocks our radiators
Found the source of the leak in mine, and it was in the exact same location. Wonder if that's a common leak point on ours. Picked up a denso radiator for $50 on Amazon and a new upper radiator hose and screw clamps.
petervivian wrote:
cptnsolo77 wrote:Sorry to hear that you had to change back to the stock bulbs. What HID projectors have you seen that fit through the opening of the stock bulb ?.....very interesting....
I don't think these will work on our cars without heavy mods to the light fixture. Our headlights have a plastic cap in front of the headlight bulb.
bigdoug wrote: Also, fixing this.
It broke at the beginning of the week. I have a temporary joiner half clamped on, but it rattles. I'm trying to see if I can get the flange apart so I can put a flange replacement on it.
I ended up fixing this not long after I posted this. Used heat and penetrant on the bolts as well as a breaker bar and was able to get the bolts out amazingly. Getting the old gasket out was fun, had to use a chisel, hammer, penetrant, and heat.
I used Walker 41727 flange to replace the broken flange. I had to cut the flange adapter's pipe in half because it was too long, there was a bend just after the flange. I also had to cut the exhaust pipe down so the new flange would fit over it. I used tin snips to cut notches in the end of the flange adapter so it would clamp properly around the existing pipe. I also took a small segment of the old pipe I had cut off and hammered it into the flange end of the adapter so the new donut gasket would have a place to sit on. I ended up using the same springs and new bolts and washers and a clamp to button it up. Hasn't given me any problems yet.
bigdoug
Post by bigdoug »
But wait, there's more!
(Since it seems you can only upload 5 pics per post, I'll just use an imgur account)
First off, I remember that someone was selling some kind of vinyl to turn your yellow taillights red. Does that person still do that, or does anyone know where I can get a small amount of vinyl cling to do it myself?
I mentioned before that I was taking apart my hatch lock to clean it out. The bolt was rusted in but I was able to pry it out. Most annoying thing was having the different lock slides launch themselves across the room. I removed all the corrosion, used a lock lube, got the whole thing back together, polished the front of it, and put it back together. I had broke part of the tab that holds the c-clip on the back, so I drilled a small hole, used a screw and washers and blue threadlock, and put it back together. Works great now.
So I did the mod for the center console 12v constant on, but did it my own way. I used wire suitcases to run 16g wire to a switch I mounted in the glove compartment because I didn't want the 12v jack to possibly drain the battery. So now the jack operates normally with the key on, or with the switch on and the key off.
Speaking of the central console, decided to replace all the hinges. Found out that there's a cheaper option for the hinge for the entire armrest. Usually the hinge costs $30 on ebay. Not bad, but if you get the hinge for the Celica 94-99 / Scion TC 05-10, Toyota part number 58907-12050, it's only $10-11 and fits our armrests with NO modification.
(The Vibe one is on the left, the TC one is on the right, but trust me, they fit without modification).
Also, the holes that the smaller hinges went into had cracked so used some tin can strips and tiny screws to better secure them.
Also changed my trans fluid early this spring. Drain plug made it easy.
One day this summer when heading to work my car refused to start. Didn't crank or anything. Figured out quickly it was the starter. Luckily I was at home, rode my bike to the parts store and picked up a new starter. Was a pain to get the starter out, had to remove the filter and oil pressure connector to get it out. I found that removing the bracket under the throttle helps to make it easier to get at the top bolt for the starter.
Over the winter a hole formed in the fender liners and caused ice and snow to destroy the washer pump. Found a new pump, as well as undamaged liners for both sides in a local junkyard. I found that the reason we get holes in the front of the wheel liners is that there's a plastic fastener right behind the headlights, one that goes vertically up into the body, that prevents the liners from hitting the tires, and mine were missing. I've replaced both and there are now no problems. If they fall out I might replace them with bolts.
Last story. This spring was terrible for potholes. While on a ramp going onto the highway I hit potholes that spanned across the entire ramp. Loud bang. Passed a dozen or more cars disabled on the road after it. Later found out it had destroyed both front struts and wheel bearings. Amazingly, I was able to get the state to reimburse me for damages, which almost never happens. There's a local repair shop that allows you to rent a bay with a lift to work on your own car, and they had a shop press, so I decided to do my own bearings. I knew how to do them but had never done them before. It went smoothly except for the snap rings that were rusted in and hard to get out. Covered the ring with penetrant, then I wedged a small screwdriver behind one end and wiggled until it popped out, then moved around the snap ring lifting the rest of it out. Also rented some bearing adaptors from autozone to help me.
If you need a bearing just get the AC Delco one from Amazon, it's the OEM one. And a new snap ring is $3 from the dealer around here. $10 for a new spindle nut.
I used an impact socket to press the hub out, didn't take a picture of that.
Here I'm pressing the bearing itself out, using an adapter to press the bearing into the tube under the knuckle.
Cleaned out the inside of the knuckle with a wire wheel.
Pressing the new bearing into the knuckle with the old bearing as a guide and adapter.
Pushing the hub into the bearing. When doing this, Do Not support the hub on the studs or you will push them out, support it by the solid metal.
Snap ring in and knuckle ready for installing. I found that a pair of 12" long needle-nose pliers worked better with those snap rings than ring pliers that were not big or wide enough.
New monroe struts.
These were on the springs. Seriously, if you don't know which end of a strut is up, maybe you shouldn't replace them!
Enough flooding the thread with images for now.
I'm painting interior panels, updating the sound system when I have money, doing some leds for the front lights, going to flush the power steering soon. Will show pictures of those as I finish them. Also, I think I'm going to use my own garage thread not just to post regular maintenance, but to post all the mods I do and how I did them.
Had to perform the "cable tie" method of securing the splash/stone shield under the front of my son's 2009 Vibe GT. He drove around awhile before noticing it and damaged it pretty good. Will have to attempt to get original clips/rivets along with cable ties to re-secure it better in a few weeks.
bigdoug
Post by bigdoug »
Well, I bought a set of brand new Blizzak winter tires for an amazing $100 that I thought were 215/60/16... misread them, they were actually 225/60/16. Oops. I've read a thread here that says they're a bit too big, 7% too big... do they rub against the wheel well or suspension? Would offsets help? Or should I just sell them again on Craigslist?
Here's my latest projects:
Changed the power steering fluid. May have to do this again as it became kinda dark again.
Replaced the control arm.
Wired up an LED third brake light
I actually don't have a picture of it lit up for some reason but it does work.
Changed the color of the instrument lights. I used blue masking tape. The lights come off a bit darker than the image, and with a subtle pattern from the tape that looks awesome. I swear I need to do a write up on this because I screwed up half the needles and spent a couple weeks or so fixing them (hint, spin the rpm and speed needle to the other side of the stopper and then use a piece of tape to mark their positions, mark the position of the gas needle with key on, and zero the temp needle when engine is dead cold (or put temp needle horizontal when it's at operating temp)).
Oh, and look at what I did with the temp gauge and some red masking tape.
Last weekend I put in blue LED bars under the dash (bars for the back seats will come later). Was a wiring adventure. Switch for it went into the spot next to the hatch glass release button.
And last but not least, today. I'm sure you guys know about the part of the rocker panel that extends into the rear wheel well, and collects dirt and leaves and crap in it. Mine had holes rusted into them. So what I did today while it was warm was cover the holes with metal drywall patch screen, and then bondo'd the holes and filled the entire cavity so things won't get stuck in them anymore. Later will come primer and then rubber undercoat!
I replaced the recirculation actuator under the dash. this worked for me::
Remove the glove box door.
Contort myself to look up under the dash.
Disconnect the wire harness from the recirc actuator. I used a small Allen wrench to get under the tab and pushed it out towards the driver side while pulling the harness back.
Wrap a 5.5 mm socket with masking tape for friction.
With the left hand feel for the screw heads.
With the right hand bring the socket to the left hand and somehow put it on a screw head.
Turn out the screw with fingers only. This would not work without tape on the socket.
Repeat with the other screw.
Wiggle the actuator off towards the driver's side.
Wiggle the new actuator on. The actuator must be rotated to drop into place.
Add and tighten the screws.
connect the wire harness.
Put glove box back.
bigdoug wrote: And last but not least, today. I'm sure you guys know about the part of the rocker panel that extends into the rear wheel well, and collects dirt and leaves and crap in it. Mine had holes rusted into them. So what I did today while it was warm was cover the holes with metal drywall patch screen, and then bondo'd the holes and filled the entire cavity so things won't get stuck in them anymore. Later will come primer and then rubber undercoat!
Very ingenious. :) I was wondering how to go about filling that area in.
The passenger side on ours has rotted away in that same spot. Driver's side is heading that way. Of course I also learned today that 1/4 of the way up the inner fender on the driver's side also has cancer. :cry: Wire brushed and sanded the best I could. Cleaned it all up and threw on 2 coats of Rustoleum Rust Reformer where needed (will fully paint the inner fenders later on.) The cladding of course kept me from doing anything with the underside, so I just sprayed a bunch of Fluid Film there.
Also sprayed some Fluid Film on the pinch welds, rear suspension and in the license plate bolt holes.
In the middle of all that, I go to open the driver's side rear door and the handle snaps off. :? Luckily a cheapo ebay spare was on hand. When I got the latch bolted back in, of course the outside handle did nothing but make an awful noise when pulling the handle. Took the latch loose again and found that the position of the blue plastic piece that runs down from the handle to the latch is apparently of great importance. All good now.
Image Image
Got to mess around with the aftermarket head unit some today (JVC KW-R910BT) after it freaked out. The right front speaker started crackling, then whatever sound that was coming from that speaker was covered up in static. After a while, the speaker went silent save for electrical whine which varied with engine speed. It was odd that the whine was only on the right front channel, all the others sounded normal.
Pulled the radio out when I returned home, didn't notice anything amiss. With the radio hanging out of the dash, fired up the engine and it sounded normal, no whine or anything. Swapped back to the original radio and went for a drive, everything sounded fantastic. I've chosen to leave her in all of her 2002-vintage audio system glory. Honestly, it sounds better with the current speakers than the JVC ever did. :lol:
Wasn't sure where the problem is as there are a number of places where something could go wrong: radio --> speaker level converter --> wiring harness adapter --> moon & tunes amp... Luckily it wasn't the amp.
I will need to revisit my wiring, I suppose. Or maybe just dump the JVC for a digital media-only receiver. Not having a CD mechanism will get me a few more inches of free space inside the dash to stash the mess of wiring that having Moon & Tunes creates.
Oh, and took her to the car wash too. Covered her up and she'll sit for a couple weeks. :D
Image Image
GORGO
Post by GORGO »
Nothing exciting,just got gas last night on the way into work.And since I live in NJ thay pump it for me.Im still contemplating on getting the takata airbag recall done.
Previously known as,TONY-TAT2 /GODZILLA
09 Base bought new. 08 Pontiac G6 the Wifes bought new. 93 Vette 40th Ruby Red Anniversary Rag top 6spd.
Viib
Post by Viib »
On Saturday, I replaced my own brake pads and rotors for the first time.
On Sunday, I fixed the dragging pad caused by replacing my own pads and rotors for the first time.
Protip: If you remove your brake caliper pins, make sure you put them back in the correct holes. They're not the same length, and the caliper will get stuck if you do it wrong. :oops:
2009 Vibe GT with 5-speed manual and shrapnel-free passenger airbag
KingKrab65
I reattached the driver's side door molding that had been detached since I bought the car. The genvibe DYI made it pretty easy to do during an unusually nice winter's day in North Carolina.
2003 Base Vibe
GORGO wrote: Mon Dec 17, 2018 4:40 pm ............And since I live in NJ they pump it for me.
Ha, I used to be that kid pumping gas on the GSP.
For my Vibe, I keep over polishing, over spraying and over detailing in order to use up all my liquids so I don't have to transport them 2500 miles in the move. I also hand scrubbed my Corolla Special Edition floor mats to make the orange colored accents pop.
Bookworm
Post by Bookworm »
Caretaker wrote: Tue Jan 08, 2019 8:32 am
Just pour them all into one bottle - that'll save you space!
OK. So I had to drive the 2004 Vibe GT last night (127k miles) to a local beer/wine tasting festival (2009 Vibe Gt had a dead battery from not driving it recently :o ). Anyways this car was officially baptized with a dose of salt/brine as we got 3" of snow and had to drive it. 15 years or so of clean driving (an inland Florida car most of it's life) and it's now going to see what corrosion looks like :( At least it may take a decade or more from this point forward before I have to deal with any corrosion problems!
Bookworm
Post by Bookworm »
tpollauf wrote: Sun Jan 13, 2019 5:35 pm OK. So I had to drive the 2004 Vibe GT last night (127k miles) to a local beer/wine tasting festival (2009 Vibe Gt had a dead battery from not driving it recently :o ). Anyways this car was officially baptized with a dose of salt/brine as we got 3" of snow and had to drive it. 15 years or so of clean driving (an inland Florida car most of it's life) and it's now going to see what corrosion looks like :( At least it may take a decade or more from this point forward before I have to deal with any corrosion problems!
From my aunt, living in Ohio, you can extend even a northern car's life indefinitely if you rinse it off before (or even after) you push it into the garage. Never understood why garages don't have floor drains.
cptnsolo77
Replaced driver side control arm again. Driver side requires to raise engine to clear one bolt. What a pain in the A$$. 4 HR job. Dont buy Ebay suspension parts.This time I installed a Moog piece, just with that alone I the front end feels tighter than the Ebay piece. I broke my golden rule : If its difficult to access OR is a vital piece, buy quality. Didnt save money because The Moog part cost 50 bucks plus 75 for a alighnment. So I actually wasted $125.00....Nuff said... :lol:
We got our first major snowstorm of this winter season! Dug out all vehicles including the 2004 Vibe GT and the 2009 Vibe Gt.
Replaced my e-brake cables the other day on the GT. While it was up on the lift in the garage I discovered some rot in the floorpan. It starts about 2 feet from the rear wheel well and runs to just about the front passenger door. See image on the Book of Faces. 272k miles and this is the biggest issue she has ever had. Sadly, it is going to be time for me to part ways with her soon.
So that got me curious about my 2007 with 183k miles... She, too, has some rot. this is more manageable being on the rocker panel. this one is on the driver side. the passenger side had a hole about the size of 50 cent piece.
Bookworm
Post by Bookworm »
Drain and fill on the transmission. Used Valvoline Max-Life (no toyota dealerships really close, and no problems with it in other Vibe)
Change the oil (overdue).
Changed air filter. Not really that dirty, but has been about 15k/6 months.
Next is changing the power steering fluid and the radiator fan assembly. (need better light to do both)
Interesting thing - with the shop lights shining through the oil, both the old oil and the old transmission fluid looked the same. Dark, but no particulates - and roughly the same colour.
Is it just me, or does the transmission take a LONG time to finish peeing?
Had to order tailgate hatch lift supports for my son's 2009 Vibe GT. "strongarm 6480" at RockAuto ! Got two of them!
did the 180 degree spin on the fresh/recirc servo today. Inner gear looked like it had one critical tooth stripped. Went with the pull dash top method for access, no way could I get my hands in there otherwise, and even with the dash off, it was still a pain to get those two 5.5mm screws out.
Since water intrusion claimed another victim, I replaced both front speakers yesterday.
When I pulled out the old Kickers, both had rust around the magnet and metal was flaking off. The labels on the back were trashed from being wet as well. I managed to get 3 years out of this set.
Went with the Pioneer TS-G650's this time. So far I'm quite pleased with the way they sound given the price paid (thank you Best Buy bucks.)
When it warms up, I'll look into getting the door sealed better and figure out what else I can do inside the door to protect the new speakers.
Image Image
Bookworm
Post by Bookworm »
ColonelPanic wrote: Sun Feb 10, 2019 5:41 pm Since water intrusion claimed another victim, I replaced both front speakers yesterday.
Make a 'roof' and glue it over the top of the speakers?
ehoff121
Post by ehoff121 »
During the cold snap last week, I noticed oil spots under the rear diff. Added some seal conditioner (https://www.amazon.com/ATP-AT-205-Re-Se ... tp+re-seal) and topped off the gear oil (took about 5 oz.) Will report back if that worked, otherwise we're doing axle seals... :(
Got a new battery from Advanced Auto- Group 35 AGM ~US$150 installed after coupon and it seemed to improve the rough idle- yes, I know that disconnecting the battery resets the idle learn, :roll: but I had disconnected the old battery (age: 6+ years) a couple of times and the idle was a bit smoother with the new AGM.
EDIT 2/18/19: I don't see any new spots on the driveway, so maybe I got lucky that 1) the seal didn't tear and 2) the stop leak swelled the seal.
treesleavedents
Post by treesleavedents »
ColonelPanic, you should invest in some foam speaker protectors. They create a foam pocket behind the speaker that the speaker then resides in. Super cheap, better sound, and no more watery speakers!
I found mine on crutchfield IIRC
