SC HELP !!!!!!
Posted: Wed Jul 04, 2012 7:46 pm
by SmAshley
So I have edited my original post instead of posting a new one!
Here's the scoop -
Followed the install instructions from GM to a tee...Only thing we can think of is...we bought the kit used and we noticed last minute while following the instructions that we never received the crank shaft pulley ... would this be a problem to anybody's knowledge..
Supercharger installed... NO START :(
Problems-
Blew thru 6 EFI fuses originally due to grounding @ the TRD ECU ... "ground wires" actually have 12.5 and 2.5 coming out of them...so we fixed that fixed that!
Now the engine will turn over but no starting.. it only caught for a spilt second and then stalled out..
All it does is turn and turn and turn and lots of fuel ... we hear the fuel pump working, relays under the hood clicking and lots of fumes from the exhaust..
But still no go :(
All Suggestions welcome!!!
Re: SC HELP BEFORE ERIE MEET THIS WEEKEND
Posted: Thu Jul 05, 2012 5:17 am
by hotbug1776
I can't shake this feeling that this may be related to one of the ECU's. Can you bypass the TRD and see if it starts, just at idle shouldn't hurt for a minute. if it cranks over on stock, there may be an issue with the TRD piggyback.
I'm going to be doing the same thing here in a few months. I'm working on buying a supercharger from a guy in Niagara, Ontario. 60,000kms(miles?) on it and he says a bad fuel line (I hope not).
Good luck with this, if worse come to worse, we may be installing a supercharger on Saturday. LOL
Posted: Thu Jul 05, 2012 6:48 am
by DiveNut
Just a thought, but sounds like you may not be getting spark. Plug a plug wire off, and see if she's sparking. Also, is it throwing a CEL? If so it may help us narrow it down for you.
Hang in there, you'll sort it out.
Pat
Posted: Thu Jul 05, 2012 1:38 pm
by SmAshley
Lots of spark no error codes...still no start... I plugged in the stock ECU and she tries to start but nothing...charging battery now due to too many start attempts...
Posted: Thu Jul 05, 2012 2:02 pm
by hotbug1776
Spark-good
Fuel-good(? Pressure checked)
Airflow-? You have vacuume? Any leaks? Iac working? Maybe try a start with the throttle just cracked open. If the iac isn't working properly, the motor will be choked off, as I don't think our throttle plates have any holes in them.
I didnt know the kit came with a new pulley. I have read posts elsewhere about the alutec pulley being used. I had only read of a new crank bolt, an ARP.
Posted: Thu Jul 05, 2012 2:15 pm
by SmAshley
So much fuel its pretty much coming out the tail pipe... she stumbles.. wants to start but no actual fire up.
Vacuum yes ... air flow check..
The pulley was just a question cuz I never saw a full kit parts list.. so I was just wondering....
Just strange that she isn't starting with the stock either..
Posted: Thu Jul 05, 2012 2:27 pm
by hotbug1776
I wish you had a way to check the ECU. I'm really leaning towards an ECU issue. I could be wrong and it could be a simple loose wire. Then again, you would throw a code, unless it's a waiting code, then no light unless it's in closed loop.
Yank your plugs, they could be fouled with all the fuel dumped on them.
Posted: Thu Jul 05, 2012 6:09 pm
by SmAshley
It runs... sorta....
Got the Stock ECU hooked up and she starts hard but runs.. pumps out all the white smoke from all the extra fuel from prior attempts at starting... we let it run to operating temp then shut it down... we then try the TRD again.. it stumbles then and stalls out and does not start again...we leave the TRD ECU hooked up and unclip the 5th injector on the SC itself and it runs ..hunts a lil (would need to adjust the idle)
this is beyond frustrating.. please see attached pic links.. (sorry facebook is way easier) and tell me GM got me to wire something wrong.
The Wiring...
http://www.facebook.com/photo.php?fbid= ... =3&theater" onclick="window.open(this.href);return false;
The Smoke :)
Posted: Thu Jul 05, 2012 7:24 pm
by hotbug1776
SmAshley wrote:It runs... sorta....
The Wiring...
The Smoke :)
gotta be your friend to see, I'll send a request
I found this...
http://matrixowners.com/index.php?/topi ... msearch__1" onclick="window.open(this.href);return false;
Posted: Mon Jul 09, 2012 2:01 pm
by SmAshley
PS - Thanks for the assistance and help !
Glad I still went down to the meet even without the Vibe.. had a great time and met some good people.
Got the vibe running now with a new intake manifold gasket for the stock setup, glad we didn't attempt the trip with the way that gasket looked when we puled it out.. we would have has less fun and stressfuk times . I am going to research this SC issue with the 5th Injector some more.. and possible look into some Emanage or just figuring out how to make the TRD/ car in general... new larger injectors like suggested in other posts.
Again thanks a mill and let the brain picking continue...
Anyones thoughts on what so do for a solution for the 5th injector issue I am having?
Posted: Tue Oct 02, 2012 4:26 pm
by SmAshley
hotbug1776 wrote:I wish you had a way to check the ECU. I'm really leaning towards an ECU issue. I could be wrong and it could be a simple loose wire. Then again, you would throw a code, unless it's a waiting code, then no light unless it's in closed loop.
We burned out the cylinders and the fuel is clear... The 5th injector is possibly the culprit!
Can anyone suggest what to do... just by-pass the 5th hear say about just putting in Larger injectors to compensate and the ECU will re-learn it all!
PLease please let me know what you all suggest !
I want to get this thing on for the spring and want to have an arsenal of tricks to attempt when we get nice weather!
Re: SC HELP !!!!!!
Posted: Tue Oct 02, 2012 10:28 pm
by Salsa Guy
Sounds like a wiring issues with the 5th injector and the ABV Switch. I think there is a red wire that is plus 12v whenever ingnition is turned on that goes to both the ABV Switch and the 5th injector, a black/white wire that goes to the 5th injector and a black/red wire that goes to the ABV Switch. If that black/white wire is grounded is will dump massive amounts of fuel in the engine. Or if they are swapped (ABV and 5th inj wires) it could do some crazy stuff also.
Using bigger injectors with the TRD ECU without the 5th injector maybe tricky. If I remember I did mess with that set-up and the engine ran lean under boost but I'm not really sure.
Re: SC HELP !!!!!!
Posted: Thu Oct 04, 2012 8:06 am
by Salsa Guy
Would like to know if you found the issue. More and More I think about it with blowing the EFI fuse it sounds like an issues with the wiring on the 5th injector and ABV switch.
Re: SC HELP !!!!!!
Posted: Mon Dec 24, 2012 12:33 pm
by SmAshley
Salsa Guy wrote:Would like to know if you found the issue. More and More I think about it with blowing the EFI fuse it sounds like an issues with the wiring on the 5th injector and ABV switch.
Honestly , we haven't had a chance to try it again. We will be tackling it again in the spring this will be the year for the charger to get in an working or its going lol
We are going to double check that we have tapped into the cars wiring harness correctly, only thing we can think of it that we may have wired up a constant power to the TRD ECU harness and thats why the 5th injector is constantly firing and flooding the engine. AKA blowing the fuses.
We are hoping to find the issues so that we can continue with other mods instead of being stuck on this. Or even worse having to dump more money into an Emanage system I would rather not shell out $$ for more to get the "plug n play" SC kit to function lol
Re: SC HELP !!!!!!
Posted: Mon Dec 24, 2012 5:07 pm
by hotbug1776
Don't give up!!! Get the emanage and 2zz injectors if need be. You will regret not having boost. I'm sure either way we can all get this figured out.
Re: SC HELP !!!!!!
Posted: Mon Dec 24, 2012 5:43 pm
by Salsa Guy
Something is wired wrong. You SHOULD NOT use a constant 12V to the TRD. Look at my wiring diagrams on MO.
http://matrixowners.com/index.php?/topi ... u-pin-out/" onclick="window.open(this.href);return false;
The E-manage or AEM is very good but will cost $1K or more after buying the it and the boomslang then the tuning. The TRD is simple but when you are splicing wire on a used kit without knowing what you are doing things will go down fast.
