Awd Tune! Help?
Salsa Guy
Awd Tune! Help?
Postby Salsa Guy » Tue Apr 19, 2011 1:57 pm
Well I'm making a trip to Dallas for my son's soccer tournament Friday (4/22) and will get a chance to put my car on a AWD Dyno. With the Dyno and Tuning it'll be $700 (ouch). They said it'll take between 5-7 hours to do the job. The place is called Jotech Motorsports( http://www.jotechracing.com/index.php ) in Garland TX. There are 3 other AWD Dynos in Dallas area (maybe more) 2 won't touch it because it's a Toyota and/or it's the Greddy EMU. The other has no experience with the Greddy EMU but willing to try it. These guys know the EMU and about the 1zz/2zz.
What should I look for and what should I expect? Should I go ahead and put the 2zz (310cc) injectors in? Should I keep the 5th injector and have them set it up (I have the wiring to the EMU done on the channel C for 5th injector)? What other questions should I ask? Would love to hear feedback?
My setup:
TRD SC (TRD Pulley)
TRD 5th Injector
Cat-Back exhaust 2.25" Crushed bent (Yea I know...get over it)
SRI
Greddy EMU
ABV Mod (Bypass Vac Switch)
Parts in hand:
2zz injectors
mac99d
Re: Awd Tune! Help? (rmckinjr)
Postby mac99d » Tue Apr 19, 2011 2:19 pm
Jotech Motorsports will do you right. I had a few friends that have gone there and were very happy.
Mac's Vibe.
My garage viewtopic.php?f=30&t=37677
Salsa Guy
Postby Salsa Guy » Sat Apr 23, 2011 4:15 pm
Well Just got back from Dallas. Jotech did a base line run of 106 WHP with the No tune. The end result was 139.4 WHP 195.2 FT/LBS Tor. I thought it could hit 140 easy. He said the 5th injector or the 2zz injectors wouldn't do much good. He also thought the SRI didn't help much either
keithvibe
Re: (rmckinjr)
Postby keithvibe » Sat Apr 23, 2011 8:37 pm
not bad. 140 for awd isn't nothing to shake a stick at
2010 Vibe & member of the year
garage
Email me if you need to talk to me, click my siggy and send the email threw the contact page.
BlueCrush
Re: (rmckinjr)
Postby BlueCrush » Sat Apr 23, 2011 11:38 pm
So you were at 106whp with the S/C with the TRD ECU?
That seems really low. I was at 107whp in 2006 without a S/C.
How many PSI are you pushing?
You're using the Alutec crank pulley, too, right?
What brand was the AWD dyno?
139.4 WHP = meh. I figured you would be above 150 with the EMU.
195.2 WTQ = seems higher than most everyone with the S/C.
So how is it now. Does it feel faster?
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
mac99d
Re: (keithvibe)
Postby mac99d » Sun Apr 24, 2011 12:05 am
Nice torque numbers. How many PSI you pushing? Maybe the SRI is causing more turbulence than he likes, and a longer one might smooth it out. So what’s the difference in CC between your injectors and the 2ZZ one’s. So did you not use the 5th injector.
Mac's Vibe.
Salsa Guy
Postby Salsa Guy » Sun Apr 24, 2011 12:12 am
Brian where have you been my TRD Adapter harness crapped out! Been running with no tune.
He said during the base line run it started to lean out at 5K. (I didn't rev it above 4K without the TRD). .
I was also surprised by the Torque. He also did the runs in first gear so I'm not sure how that affects the numbers. He ran it 11 times on the Dyno. What also surprised me is that he felt the 5th injector or the 2zz injectors wouldn't do it much good. Also he said I could ditch the SRI and not affect the tune
BlueCrush
Re: (rmckinjr)
Postby BlueCrush » Sun Apr 24, 2011 12:18 am
Oh, that's on the stock ECU? That's not good. 1st gear tq is way higher than 3rd gear torque which is where official dyno readings are typically taken. Somewhere around 40-45 in 3rd gear(Drive with the OD button off), if you are cruising you can floor it and not downshift. My 1st gear torque on my baseline dyno run in 2006 was 160 ft/lbs.
My Fleet:
Salsa Guy
Re: (mac99d)
Postby Salsa Guy » Sun Apr 24, 2011 12:22 am
Quote, originally posted by mac99d »
Only about 7- 8 of HOT Air (he pointed that out). The 1zz are about 240cc the 2zz 310cc. the 5th injector was setup for the Greddy EMU but he said fuel wasn't the issue.
BUT what really cool about in his shop was the all the very nice cars GTRS (about 6 of them), a Bentley, a Lambo, a Ferrari and several debagded cars I wasn't sure of.
BlueCrush
Re: (rmckinjr)
Postby BlueCrush » Sun Apr 24, 2011 12:26 am
Quote, originally posted by rmckinjr »
Only about 7- 8 of HOT Air (he pointed that out). The 1zz are about 240cc the 2zz 310cc. the 5th injector was setup for the Greddy EMU but he said fuel was the issue.
What was the issue with the fuel?
My Fleet:
mac99d
Re: (BlueCrush)
Postby mac99d » Sun Apr 24, 2011 12:37 am
Fuel will never be a problem for me, but I am running bosch 840cc kind of over kill but will keep up with future plans.
Mac's Vibe.
Salsa Guy
Re: (BlueCrush)
Postby Salsa Guy » Sun Apr 24, 2011 12:40 am
Quote, originally posted by BlueCrush »
Sorry all WASN'T an Issue. Will edit!
keithvibe
Re: (rmckinjr)
Postby keithvibe » Sun Apr 24, 2011 12:57 am
first gear.... (removed)... really...
As B has stated it's usually done in third... the closest 1:1 ratio...
Running in first has totally booggered ya.. The tune will be off a bit where you run the most (in third) I'm shocked that such a tunner would even do such a thing...
Mine was run in second, I tried to tell the guy to let me run it in third. I would have been able to keep it from downshifting from 3rd to 2nd. But he didn't want me to do it for what ever reason and the three times he tried it would downshift.
garage
Salsa Guy
Postby Salsa Guy » Sun Apr 24, 2011 1:11 am
This sound like an expensive lesson. Oh well this was a very cheap build and I'm not competely happy with the results. It is a starting point.
DiveNut
Re: (rmckinjr)
Postby DiveNut » Sun Apr 24, 2011 5:16 am
Yes it is rmckinjr.
Us gearheads are never totally satisfied with the results of our mods brother. We always what a little bit more!!! Enjoy the build and keep us posted as your mod list grows (and it will ) Remember, you now have one of the fastest AWD Vibes out there. Very cool.
Pat
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
Salsa Guy
Re: (DiveNut)
Postby Salsa Guy » Sun Apr 24, 2011 6:18 am
Quote, originally posted by DiveNut »
LOL Except it's a Matrix..... Maybe I need to rebadge it? LOL
BlueCrush
Re: (DiveNut)
Postby BlueCrush » Sun Apr 24, 2011 6:30 am
Same thing...haha!
My Fleet:
DiveNut
Re: (BlueCrush)
Postby DiveNut » Sun Apr 24, 2011 7:54 am
Same thing...haha!
Yep!! Though not as easy on the eyes as our Vibes LOL! (Just kidding rmckinjr )
Salsa Guy
Re: (BlueCrush)
Postby Salsa Guy » Sun Apr 24, 2011 9:13 am
Same thing...haha!
Ya think!
Salsa Guy
Re: (DiveNut)
Postby Salsa Guy » Sun Apr 24, 2011 9:17 am
It's sad that Pontiac couldn't build a good car and that Toyota had to do it for them (I'm just poking fun...don't need hate mail). But Pontiac made it prettier...and they have more power (old joke).
Salsa Guy
Postby Salsa Guy » Tue May 03, 2011 7:24 am
Well I dumped the Tune at the AWD place and used one from a guy on MO, and it works GREAT! My AFR is 12.3 on WOT! It pulls AWESOME with no lag and the idle has improved. I was about ready to rip the SC out and the EMU but now I'll keep it
BlueCrush
Re: (rmckinjr)
Postby BlueCrush » Tue May 03, 2011 7:26 am
Good to hear you got it solved, Rob. Now you can enjoy it instead of worrying about it.
My Fleet:
keithvibe
Re: (rmckinjr)
Postby keithvibe » Tue May 03, 2011 7:59 am
ricker's got you sorted out??? i'm happy to hear you are finally enjoying it.
garage
Salsa Guy
Postby Salsa Guy » Tue May 03, 2011 8:38 am
Brian: Thanks! Keith: Yes he did! It's a HUGE difference and a load off my mind.
Salsa Guy
Re: Awd Tune! Help? (mac99d)
Postby Salsa Guy » Fri Jun 10, 2011 4:43 am
Well they didn't do me right and had to dump the tune (almost ruined the engine and got me killed). The CC company gave me a full refund from Jotech. That's everyone for your help!
Return to “Forced Induction”
Who is online
Users browsing this forum: No registered users and 1 guest
