TRD SC ECU Problem
Supercharger, turbo, nitrous, and anything that has to do with forced induction
Salsa Guy
TRD SC ECU Problem
Post by Salsa Guy »
This post started in engine issues but not it appears to have something to with the TRD ECU or Wiring harness here's the thread if you want to read more http://forums.genvibe.com/zerothread?id=43781For S&Gs I plugged my new TRD ECU for M/T in the harness. It also caused my lights to flicker and engine to miss. So now I'm looking at the TRD ECU Plug in adapter and wiring harness from my issue. Spending Several hours tracking down the connections between the ECU and TRD ECU I've come up with a pin-out between the 2. This is looking at TRD ECU adapter (PN# 00602-17620-135, RCON 1803 1.0, DOC# 17620-178) where the Engine and TRD wiring harness are connected. TRD > Eng > ECU > DescriptionCON > CON > CON 1 >>> E4-5 >> E4-5 > HT1A/HT1B (GROUND) 2 >>> E4-5 >> E4-5 > HT1A/HT1B (GROUND) 3 >>> E3-28> E3-28> PTNK/VC/THW/THA/VTA (GROUND) 4 >>> E3-28> E3-28> PTNK/VC/THW/THA/VTA (GROUND) 7 >>> E4-24> >>>>> VG MAF from Engine to TRD ECU 8 >>> E3-21> E3-21> VTA THROTTLE POS 9 >>> E9-19> E3-19> THW TEMP WTR 10>> E3-20> E3-20> THA TEMP AIR 11>> E4-23> >>>>> OX1A OXYGEN SENSOR1 from Eng to TRD ECU 12>> E4-1 >> E4-1 > KNK1 KNOCK SENSOR 13>> E4-2 >> E4-2 > EKNK KNOCK SENSOR GROUND 14>> >>>>> E4-24> VG MAF from TRD ECU to ECU 15>> >>>>> E4-23> OX1A OXYGEN SENSOR From TRD ECU to ECU 16>> E3-27> E3-27> NE+ CRANKSHAFT POS 17>> E3-34> E3-34> NE- CRANK/CAM POS GROUND 18>> E3-26> E3-26> G22+ CAMSHAFT POS 19>> >>>>>> E3-8 > IGT1 From ECU to TRD ECU 21>> E3-8 > >>>>>> IGT1 From TRD ECU to Eng 22>> E3-9 > >>>>>> IGT2 From TRD ECU to Eng 23>> E3-10> >>>>>> IGT3 From TRD ECU to Eng 24>> E3-11> >>>>>> IGT4 From TRD ECU to Eng
Salsa Guy
Post by Salsa Guy »
Also contrary to someone else's statement the TRD ECU does NOT change the Air Temp measurement. It does change the the MAF and Oxygen Sensor measurements and of course Ignition timing
Salsa Guy
Post by Salsa Guy »
FYI, I got the car back on the road with the TRD AT ECU. I've gone through the wiring harness at the ECU and found a few wires that maybe "suspect". Hopefully this will allow me to get the Catback done and turn it over to a local "tuner" and get the Greddy EMU in. I hope the TRD ECU pinout helps some people down the line.
