SC Belt Problems
Petrucci914
SC Belt Problems
Post by Petrucci914 » Sun Feb 20, 2011 3:34 am
Hey everyone.....It's been a long time, but I'm still here!I continue to have issues with my belt. It used to not stay lined up correctly but that seems to be all right now. I still get quite a bit of squeaking when I start up. Sometimes it seems like it is stuck or something because the RPM's will waiver at idle and sometimes acceleration seems blunted. I used to have the Gatorback belt but I don't know if there is a better belt. I did get a Smoothflow Pulley but didn't have to change belt size for it.........can I get away with a slightly smaller belt? Ideas?
BlueCrush
Re: SC Belt Problems (Petrucci914)
Post by BlueCrush » Sun Feb 20, 2011 4:30 am
Hey Adam! How's it going? So is the belt you have on now the gatorback or the one that came with the S/C kit?
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Petrucci914
Re: SC Belt Problems (BlueCrush)
Post by Petrucci914 » Sun Feb 20, 2011 4:56 am
Hey man!I think I have a Dayco one on it now. I've always had issues with the belting on this thing and all the shimming. Maybe I should just take it in and tell the mechanic to do whatever he can to make it work. I know it is messing with my performance and mileage.
Salsa Guy
Post by Salsa Guy » Sun Feb 20, 2011 6:40 am
Check the idler pulley bearing. Make sure it isn't dried out or doesn't have play in it. Should be a $25 items
Petrucci914
Re: (rmckinjr)
Post by Petrucci914 » Mon Feb 21, 2011 11:35 am
I'll have to check that.What is the size of the stock SC'er pulley? I have the 2.3" Smoothflow Pulley..........trying to see if I can get away with using a smaller belt.
DiveNut
Re: (rmckinjr)
Post by DiveNut » Tue Feb 22, 2011 2:51 am
My idler puller was squealling at start-up. Hit it ( a couple times) with some wd-40 while the car was idling and has been quiet ever since. I think I may have gotten some moisture in there after hitting a large puddle. The squealing started the next day. Stock SC pulley is 2.4"Good luck man.
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
Petrucci914
Re: (DiveNut)
Post by Petrucci914 » Tue Mar 01, 2011 11:38 pm
I shot some WD-40 in there.......didn't make a difference. A lot of times it'll squeal when putting it in reverse. Sometimes I can feel it slipping because the RPM's will jump a bit. Generally works better when warmed up.Could I get away with a smaller belt? How much smaller could I go?
mac99d
Re: (Petrucci914)
Post by mac99d » Thu Mar 03, 2011 11:28 am
take the one you have off take it to auto zone buy two or three that are a little smaller try them all out keep the one that works take the others back. they wont care as long as you dont mess them up.
Mac's Vibe.
Petrucci914
Re: (mac99d)
Post by Petrucci914 » Mon Mar 14, 2011 10:32 pm
Put a belt on that is .5" shorter. Car runs better now than it EVER did. No laboring or anything. Hitting 8-9PSI.
BlueCrush
Re: (Petrucci914)
Post by BlueCrush » Mon Mar 14, 2011 11:04 pm
Quote, originally posted by Petrucci914 »Put a belt on that is .5" shorter. Car runs better now than it EVER did. No laboring or anything. Hitting 8-9PSI.Good deal! What is the brand & size of the belt you bought?
My Fleet:
