Turbocharging the 2009 vibe?
Faultline
Postby Faultline » Mon Oct 27, 2008 2:49 pm
When Toyota made the 2zz motor, one of the objectives was to engineer a 1.8 liter motor with the power output of a 2.4 motor.
They built a great motor, but it is not the easiest to turbocharge because of the highcompression pistons. And eventhough the stock 2zz motor puts out 180 hp, it still lacks lowend torque.
Now here we are with this large 2.4 four cylinder motor that has vvt-i, great torque , and easy to turbo motor. I am jealous with the motor size. Scion TC forums are boasting a lot of cars with this same Camry motor (that is in the new vibe) making around 300whp turbocharged.
I would love to do it but ......and you know I would..but I still love my car right now, and ...I dunno about buying a new Vibe,,,but then I am so enticed.....Is there anyone on this board with a 2009 Vibe that is planning on going turbo??? Come on!
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/
2003 Base Vibe, frosty color,moon n' tunes package
mods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmission
Stafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
NibCrom
Re: Turbocharging the 2009 vibe? (Faultline)
Postby NibCrom » Mon Oct 27, 2008 10:37 pm
If you really wanted a turbo four-cylinder, I'd recommend buying one from the factory (like a Cobalt SS) instead of modding a car.
northvibe
Postby northvibe » Tue Oct 28, 2008 12:32 am
the scion tC has that same engine and there is a turbo kit for it. I have not seen one made specifically for the matrix/vibe but im sure its easier than a home made kit. Biggest issue is header/manifold and tuning.
Your best bet is to check matrixowners.com (they are more into modding than gv) and wait for a kit to be made.
2009 Cobalt SS
Quote, originally posted by northvibe »
ABS is really for lazy americans
Faultline
Re: Turbocharging the 2009 vibe? (NibCrom)
Postby Faultline » Tue Oct 28, 2008 3:23 pm
Quote, originally posted by NibCrom »
Booooo!! where is the novelty? where is the fun? what about adventure? or risk?
Besides everybody I know with a factory turboed car is modding it too.
Sometimes it is bigger IC, or bigger turbo, or something....
A factory turbo car , unfortunately, would not cure my disease...
There is always more power to gain ....it's fun.
Faultline
Re: (northvibe)
Postby Faultline » Tue Oct 28, 2008 3:47 pm
Yeah, I will. As for me, with what I have learned, I dont need to go thru astronaut school to get on the rocketship again. I mean, I dont need a kit, I would rather have one made the way i want.
For example, most kit turbo manifolds that I have seen are not as
beefy as I would like, so why buy a kit one that may crack?
I know how to make a boost controller for five dollars, or a water injection kit for ten. I know how to run a rich mixture in the fuel and not retard the timing and make good power on stock injectors without a piggyback, or stand alone fuel computer , and larger injectors. ( dont get me wrong, I have some of that stuff now, but I know how to make it work without)
Its just stuff I learned from the guy who installed my turbo set up, and
He did not learn his stuff from magazines, or from people who are selling turbo products.
I have been driving my turbo vibe for too long to feel differently.
Raven
Postby Raven » Wed Oct 29, 2008 12:16 am
The Cobalt SS is supercharged not turbo.
NibCrom
Re: Turbocharging the 2009 vibe? (Raven)
Postby NibCrom » Wed Oct 29, 2008 2:42 am
Quote, originally posted by Raven »
The new one is turbocharged.
http://www.caranddriver.com/re....html
Raven
Postby Raven » Wed Oct 29, 2008 5:20 am
The new one is turbo[QUOTE=NibCrom]
[/QUOTE]
You're so right. 260HP Turbo MMMMMM!
That's 15 more than my SVX in a lighter car too.
NibCrom
Postby NibCrom » Wed Oct 29, 2008 6:00 am
Quote, originally posted by Faultline »
I think the best thing about buying say the Cobalt SS from the factory is that not only do you start with a good engine, but the suspension and the brakes are up to par with the engine.
But if you're addicted to mods, that's fine too.
Faultline
Postby Faultline » Wed Oct 29, 2008 2:35 pm
Yeah, that is a point well taken. You could add to the list RWD, or at least a FWD with a 'limited slip differential'And wider tires.
Do you happen to know if the' turbo cobalt' is going to have the same turbo motor as the Pontiac Solstice??
NibCrom
Postby NibCrom » Wed Oct 29, 2008 10:13 pm
Yup, the Cobalt SS Turbo has the same 2.0L direct injection engine with VVT as the Pontiac Solstice GXP, Saturn Sky Redline the HHR SS as well. LSD is a $495 option I believe.
northvibe
Postby northvibe » Mon Jul 06, 2009 12:29 pm
heck yes I made sure my SS came with a LSD! :D There is nothing like the reliability of a factory FI car. I dont have the time or space to work on my car more than a oil change and rotate the tires. so it works perfect.
2009 Cobalt SS
AKLGT
Postby AKLGT » Mon Jul 06, 2009 12:44 pm
yes, we decided to start with a factory FI car and then go from there. the only turbo'd NEW car I'd probably leave alone (for the most part) is a new GTR.
AKLGT
1998 Subaru 2.5RS
tunertype
Re: (AKLGT)
Postby tunertype » Mon Aug 03, 2009 2:41 pm
Factory turbo is much easier to modify and get big HP. Instead of dropping in headers downpipe intercooler, turbo, pistons and ecu to get an extra 50-100hp(2000+$).. you can pop a high flow exhaust and a boost controller onto your factory turbo car and get an extra 50hp easy(500$). or just a new turbo and injectors and get 100hp very easy(700$). factory supercharged cars on the other hand are in the same boat as factory NA cars. the best you can hope for is to change out a pully and reflash the computer. after that it's time to rip out the supercharger and turbo or turbo on top of the supercharger.(supercharger spools up turbo to give you that low end power like a twin turbo setup). If you want something more like a vibe look into a WRX hatchback or a mazda speed3. both can be had used for around 15k.
vibedrivermatt
Re: (tunertype)
Postby vibedrivermatt » Tue Sep 08, 2009 6:56 am
well sure from a practical standpoint you could easily afford an older more sporty car for the price on a 2009 vibe but putting practicality aside, I think somebody should make do a Turbo 2AZ-FE vibe. Put a limited slip on there too and a performance cluctch. Theres a lot of aftermarket scion engine parts out by now that might work on the vibes engine. I even saw some hardened steel crankshafts.
jerryn
Postby jerryn » Thu Oct 29, 2009 2:58 am
How about dropping in a TRD supercharger? It's self contained so it does not need to be lubricated with engine oil.
jerryn
Re: (tunertype)
Postby jerryn » Thu Oct 29, 2009 3:07 am
My 2001 turbo beetle was like that. You could chip it I must have replace the blow off valves 5 times while I owned that car. the first time was at the dealer, after that I did it myself.. I got many bloody knuckles replacing that. I traded it after I had a vivid dream of rolling the car.
It was fast, but suffered from terrible torque steer. Punch the accelerator, rev to 4300k rpms.. let out the clutch and you have no idea of what wheel is gonna grab first!!!!! sometimes the right, sometimes the left..
Wolfman213
Postby Wolfman213 » Thu Oct 29, 2009 3:47 am
I'm still hoping someone in any year Vibe would try out a STS Turbo!!
April 2010 Co-MOTM * Custom LED Gauge Cluster swap * LED dome, HVAC, and shifter * Retrofit projector w/ blue halo * Kenwood KDC-HD942U * Herculined cargo area * Debadged *
Wolfman's Garage
Faultline
Re: (Wolfman213)
Postby Faultline » Wed Feb 03, 2010 6:27 am
Quote, originally posted by Wolfman213 »
I think that a Matrix owner did a couple of years ago.
mikellini
Re: (Faultline)
Postby mikellini » Wed Feb 03, 2010 2:33 pm
I think I might go with the TRD supercharger in a year or two. Adds about 75 horsepower in a couple of hours and wouldn't be too much for the stock internals and 5 speed auto. Would be nice to have limited slip though
northvibe
Re: (mikellini)
Postby northvibe » Wed Feb 03, 2010 10:18 pm
Quote, originally posted by mikellini »
what year vibe? the old 1zz trd SC's are getting insane hard to find. and all are used now. I havent heard or seen someone take a TRD tC supercharger and put it on though...which I still find odd.
2009 Cobalt SS
mikellini
Re: (northvibe)
Postby mikellini » Wed Feb 03, 2010 10:20 pm
I've got the 2009 2.4 2AZ-FE, I believe those are going to be available new for quite some time as it's a very common performance engine. Not sure on the price though...
northvibe
Postby northvibe » Wed Feb 03, 2010 10:34 pm
the scion tC one yes..but they charge an insane amount new. And again I've never seen one put on a vibe/trix...which I'm not sure why...
Although someone procharged a ion and the problem is the belt slips when you make too much power...or maybe he didnt have the right belt as vettes do it fine.
2009 Cobalt SS
mikellini
Re: (northvibe)
Postby mikellini » Wed Feb 03, 2010 10:46 pm
I really don't know, I mean for what this car is for, it doesn't need a buttload of power. Intake and exhaust can add another 15 hp, correct? Without spending a bunch on FI, are there any other mods that could bring it up to about 200 HP?
northvibe
Postby northvibe » Wed Feb 03, 2010 10:55 pm
well you can always do cams, tune, intake, exhaust headers and full exhaust back. Nitrous but that imo doesnt count. Tuning imo would net you the most power.
Oh well theres also making your car lighter, which is what I'm doing to my car. And under drive or lightweight pullies but those can ruin a engine. Like on the 2zz, they had issues with harmonic balance and blowing a oil pump.
2009 Cobalt SS
CoryW
Postby CoryW » Wed Feb 24, 2010 2:39 am
http://cgi.ebay.ca/ebaymotors/...19366
Looks too good to be true.
1100 for the whole kit. the turbo should be woth more then that alone
tunertype
Postby tunertype » Mon Mar 15, 2010 12:46 pm
Hmm.. wouldn't buy a cobalt gm econobox.. blah.. Maybe a WRX, a jetta/golf turbo, or a saab. Not a cobalt.. ick.. turbo cars are easier to modify and get lots more F/I hp out of cause they're engineered to be turboed though. Buying a cobalt would be like buying a honda civic and calling it a sports car.. blah.. Honda has some nice cars like the NSX and the S2000, but civic.. ick..
Quote, originally posted by CoryW »
This kit is missing a few things. It'd be a good starting point for a custom turbo setup, but just the stuff in this kit will not get you anywhere, and the turbo is very low quality. You need to add a down pipe and a dump pipe custom made. You need engine management either a piggy back or a standalone unit, and you also need some bigger injectors(at lower power levels a fuel pressure regulator and a fuel pump might do the trick) to produce more power. So buy this kit and add in another 1000 in extra parts. You'll have a complete custom turbo kit that is not bolt on and needs alot of labor and modification for 2000$. If you know what your doing and are a good fabricator this can save you about 1000-2000 over buying a complete simple bolt on kit that has instructions.
BLargal
Re: Turbocharging the 2009 vibe? (tunertype)
Postby BLargal » Sun Feb 27, 2011 5:16 pm
Not sure if I wanna turbo charge my 09 since I just got it. I'm pretty content with the speed I get out of it. I think this summer i'll get my friend to help me put in a new air filter and the such but no turbo I just don't got the money.
joshuaeb09
Re: Turbocharging the 2009 vibe? (BLargal)
Postby joshuaeb09 » Fri Jul 08, 2011 12:44 am
Quote, originally posted by BLargal »
Check out my garage now. I'm very happy with what I've gotten out of the 2.4L N/A.
Plus with the unichip if I ever go boost I just have to get an additional module and I can retune for boost.
2009 Silver Vibe GT AutomaticI/H/E/Unichip @ 93octaneMy Garage : http://forums.genvibe.com/zerothread?id=43521 - Gone (Sold)
2005 Expedition Limited 2WD|4R75W 4SPD Auto|3.73 Gears|I/E|5Star Tuned@ 91|3" Lift/Level - Current Ride
B14CK_H4WK
Postby B14CK_H4WK » Fri Jul 08, 2011 4:44 pm
VVTI has been good to me and im sure you can all say the same. there's no fun in buying a car already turboed and plus its all about being unique, how many ppl are going to have a turbo vibe?
mac99d
Re: (B14CK_H4WK)
Postby mac99d » Sat Jul 09, 2011 2:18 pm
Who is turbo? And supercharged? Do we have a list for this I know faultline, keithvibe, and I are turbo. Who else? Queue in the really smart computer guy that can whip up lists like a mad man.
Mac's Vibe.
My garage viewtopic.php?f=30&t=37677
Mariachi
Postby Mariachi » Thu Aug 11, 2011 1:03 am
I saw this car in a magazine. Can't remember which one but its a turbo'd Matrix.
Return to “Forced Induction”
Who is online
Users browsing this forum: No registered users and 1 guest
