someone posted a thread about safe shots before and I mentioned running a 100hp shot, here is how I set up systems on some cars... kinda trick and expensive... but works great. everything RED is fuel BLUE is NOS the basic set-up is direct-port -but with an independent fuel system we run 118 octane fuel in the fuel cell, an entirely seperate fuel system for the NOS system. The pump does not turn on untill you arm the system. You should be able to fit this all under the hood except the bottle.did the diagram fast sorry kinda messy
