CELICA GTS TO VIBE GT ECM. WILL IT WORK?
302LVR
Post by 302LVR » Fri Jun 02, 2017 11:05 am
Hey guys. I was wondering if a celica gts ecm will work on an 03' Vibe gt being that they're both 2zz powered? I may be having issues with my ecm and saw a gts at my local junkyard the other day so was planning on picking it up but i'm not sure if they're compatible. Any feedback would be appreciated. Thanks.
runningslow
Re: CELICA GTS TO VIBE GT ECM. WILL IT WORK?
Post by runningslow » Thu Jul 06, 2017 11:22 am
Probably way to late for a response, but no, it wouldn't work. You need a Vibe GT ECU. I think you could get away with an 04 ECU in your 03, but the 03 is the preferred model. I don't believe that even a Matrix ECU would work.
Josh
2005 Vibe GT ~ Platinum
2006 Vibe ~ Lava, Base, Auto
302LVR
Post by 302LVR » Thu Jul 27, 2017 7:18 pm
Thanks for the feedback. I was considering getting another ecm cuz i thought mine went bad after an accident since the car would crank but wouldn't fire up. Did a compression test shortly after n found out i have a blown head gasket n that's why the car won't start.
