Hello all. I tried researching to see if anyone elses symptoms matched mine, but I didn't see a similar case yet. Sorry if I missed a thread about this...
I replaced the blower motor in May of 2014. Also fixed the interior circulation "clicking" problem at one point.
This new problem is concerning the fan. It starts and stops at random. When it works, it blows on all fan speed / settings. For a while, when it would stop, I could turn the switch on and off several times and it would start back up. Could this mean the 2.5 year old blower motor is already going bad?
It'll go days without running. And then, like today, I tried turning it on several times, didn't work until 2 hours of driving around.
Anyway to diagnose?
The a/c itself isn't the problem. While the fan isn't working, I can activate the A/C, and cold air slowly comes out just from exterior air intake. Same with heat, if I switch the thermostat to heat, temp is fine.
Thanks for any suggestions!
