2007 pontiac vibe base model 5 speed manual. I went to start my car and the seatbelt beeper beeped once and all the lights went out! I have no dash lights (except check engine and airbag, and door open when the door is open) no tail lights, no reverse lights, the 110V outlet dosnt work, signals dont work, brights dont stay on, headlight dont work, but the radio does work and so do 4 ways. I really need help here, i need the car to go to work on Monday and dont have a whole lot of money to fix. Any help is much appreciated.
Did you turn the key hear the starter engage, then the everything went out? Or were you getting ready to turn the key and noticed the lights were out. Their is a fuse and relay control box on the driver side just up from the battery. Their are some other threads on the site that might help:
Here is a diagram of how the car system tie together http://forums.genvibe.com/files/importe ... -012ps.pdf
This post mentions the tail lights, not sure same circuit powers the dash viewtopic.php?f=33&t=43548&p=497992&hil ... ht#p497992
I turned the key to the on position but didnt try to start it, then the seatbelt chime dinged once and stopped which has never happened before and then there was no dash. The car starts and runs just fine but i cant see any of the dash.
Time to get out your voltmeter and start tracing down where you lost power (voltage) at in the electrical system and check for shorts to ground. Remember that fuses are a safety device and never the cause. A blown fuse is the result of a problem somewhere in that electrical branch and not the problem. The fuse will tel you which branch you need to check out.
