So i've seen and read some of the posts on swapping out clusters in 03 to an 04, unfortunately the pictures that are with the guides are no longer available and no one wants to do it in this area for under $300. So That being said, are the LED's behind the 03 cluster faces red or white? If so, are the faces of the tachometers interchangeable? For example if i remove the 04 speedometer face and put it on the 03 will it come out as red? I figured if so this would be a much cheaper, easier way of getting that 04 cluster look in the vehicle.
