A/C air temp question
BC123
Post by BC123 »
I have a 2009 GT with the 2.4 and about 72,000 miles. I have recently recharged my a/c system. It was down about 3.5 oz but other than that everything was normal. It works and gets cold but searching the net the typical temp seems to be lower than what I'm getting. I have a meat thermometer in a vent and consistently get about 50 degrees on max fan and recycle. I live in Florida so it's hot out but wanted to know of this is a normal temp to expect if not any suggestions to drop the temp. Thanks!!
SeattleJeremy
Re: A/C air temp question
Post by SeattleJeremy »
I have very little knowledge on this subject, but the guys at Autoline did a feature on AC repair recently.
https://www.youtube.com/watch?v=0QXbNAtwf2Y" onclick="window.open(this.href);return false;
I can't find the capacity of the 2009+ 2.4L Vibe\Matrix but it's likely less than the 18oz the 2003 Vibe had.
Did you take it to a shop to have it filled or did you fill it your self with a kit?
Turo'ing 15' BMW 328i Sport - Jet Black - Auto
Daily 19' Toyota Camry SE Hybrid - Galactic Aqua Mica - eCVT
ArcsVibe
Post by ArcsVibe »
BC123 wrote:I have a 2009 GT with the 2.4 and about 72,000 miles. I have recently recharged my a/c system. It was down about 3.5 oz but other than that everything was normal. It works and gets cold but searching the net the typical temp seems to be lower than what I'm getting. I have a meat thermometer in a vent and consistently get about 50 degrees on max fan and recycle. I live in Florida so it's hot out but wanted to know of this is a normal temp to expect if not any suggestions to drop the temp. Thanks!!
Did you also replace your cabin filter? I know that after I had some AC work on my Mazda 3, once I changed the cabin filter (PIA btw) it blew colder air.
Keep us posted!
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
beemerphile1
Post by beemerphile1 »
You check the AC output by comparing the input temperature and output temperature. If the air going into the system was 70 and the air coming out was 50, you are working correctly.
Edit to add;
Use the recirculate function. If you draw in outside air it will cool it by 20 degrees. Example; 90 degrees outside air will be cooled to 70 degrees. If you recirculate the cabin air it will be cooling air that is already cooler than the outside air. Example; 70 degrees cabin air will be cooled to 50 degrees.
Water boy
Post by Water boy »
A/C is generally rated in "Degree Days".
If your system, say at home, is rated for "20 Degree Day" then if the temp outside is 100* it can cool the inside down to 80*. Sure you can get a system to cool that down to 70* but the cost is a lot higher for the equipment. It is a balancing act usually driven by your checkbook. Why spend an extra $1000 to get that 70* on just 3 days a year at 100*. Of course there are other factors but I'm talking generally.
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
