haha I used to want to get the beep mod on the vibe but noticed the door locks pretty loudly so didn't need it09vGT wrote:Why do you need a "chirp" when you have the "thunk"? Totally joking, kind of. When the hatch locks or unlocks it is LOUD.
Hummm...never noticed.lowincash wrote:btw, anyone notice the third brake light will light up dimly when you lock/unlock the car? I only see this at night sometimes.
I have never noticed this but will check it out when I go outside in a bit ...lowincash wrote:btw, anyone notice the third brake light will light up dimly when you lock/unlock the car? I only see this at night sometimes.
It may not be the same for the 1st gen Vibes because the 2nd gen Vibe 3rd brake lights are LEDs.Water boy wrote:Hummm...never noticed.
But then again, the bulbs are burned out.
Maybe I'll remember to check after I put in some LEDs.
Neither one of our Vibes do this. I literally stuck my face right up by the hatch glass since our windows are tinted and hit all the buttons on the keyfob. No light whatsoever from the 3rd brake light. Must have been a fluke with your Vibe Kin .vibenvy wrote:I have never noticed this but will check it out when I go outside in a bit ...lowincash wrote:btw, anyone notice the third brake light will light up dimly when you lock/unlock the car? I only see this at night sometimes.
The chirp Toyotas make is very quiet, rather than the chirp that alarm sirens make.Zimm wrote:i've never heard anyone wanting to add a chirp. if anything, people usually try to remove them out of courtesy to the neighborhood or just because the mechanical clack of the lock mechanism is obvious enough.
vibenvy wrote:Neither one of our Vibes do this. I literally stuck my face right up by the hatch glass since our windows are tinted and hit all the buttons on the keyfob. No light whatsoever from the 3rd brake light. Must have been a fluke with your Vibe Kin .vibenvy wrote:I have never noticed this but will check it out when I go outside in a bit ...lowincash wrote:btw, anyone notice the third brake light will light up dimly when you lock/unlock the car? I only see this at night sometimes.
