Thanks for the help.
*I hope this is the correct place for this thread...apologies if not.
BTW: Have you had the car scanned to see if it's throwing any codes? It will fail inspection if there are active codes too.Remove the gauge cluster from the dash. Lower the Steering wheel to the lowest setting, and lock it in place. On a Matrix/Vibe pull on the round chrome shroud that surrounds the gauge cluster (it will come off easily). There is one Philips head screw, that needs to be removed at the top center. There are two clips that hold the gauge cluster in place, on the far left and right bottom. With a flash light you should be able to see them. With your screwdriver push the top of the clip, and it should come loose. The arrow below shows where to push on the clip.
When the cluster is free, move the bottom forward and the top back. Then disconnect the wiring harness’ (03-04 has one harness, 05-08 has two). Then remove it from the dash, and take it to a well lit place.
