Headlight Bulb Connector / Socket Replacement
msmyer
Post by msmyer »
My light harness and socket damaged and I need the GM part number? Also, is the Toyota part compatible? Below is what I need:http://www.ebay.com/itm/160653...l2649
‘03 Vibe with 317k and still going.............................
Other Mods: Sony X-Plod Headunit & Reflective White GVC decalMy Car at Cardomain.com... http://www.cardomain.com/id/msmyer
Re: Headlight Bulb Connector / Socket Replacement (msmyer)
I know the headlight bulbs are different between Vibes and Matrix so I'd bet the sockets are different also.I don't know the part numbers, but its good to see you back, even if its for problems.
