HID's in fog question
WhiteFiver
Post by WhiteFiver »
I'm putting a set of 5000K 35W HID's in my fog lights on my 2004 Vibe Base. Should I use a relay harness, or can I just use the stock wiring.?
2008 G5. K&N SRI, 16x7 Akita AK-7, Painting, CCFL Projectors, tinted tails.2004 Vibe Base, 160,xxx KM, 37,xxx KM on motor
keithvibe
Re: HID's in fog question (WhiteFiver)
Post by keithvibe »
you should be fine with the stock wiring. If for some reason you have one that won't light or every now and again then yes add the relay harness.If you went to the 55watt hids then YES get the extra harness. But I don't recommend using the 55watt kits.
06pvibe
Post by 06pvibe »
You shouldn't do it @ all w/the OE fog light housing. They are not projectors, nor even have a light diffuser. It is illegal for a good reason. The scattered light created will blind other drivers.Install projectors designed for HIDs if you plan to do this mod. That is the only correct and legal way.
06pvibe
Re: HID's in fog question (keithvibe)
Post by 06pvibe »
Quote, originally posted by keithvibe »you should be fine with the stock wiring. If for some reason you have one that won't light or every now and again then yes add the relay harness.If you went to the 55watt hids then YES get the extra harness. But I don't recommend using the 55watt kits. I wonder why you say that? Halogens= 55w drawHIDs= 35-55w draw. Same-same, no? 55w's is 55w's in my book.
hskater26
Re: HID's in fog question (06pvibe)
Post by hskater26 »
i have 3000k HIDs in my fogs and i have driven at my car in another car and they are no where near blinding. most likely because they are lower.
-2003 Base Vibe-2002 Ducati ST2
hskater26
Re: HID's in fog question (hskater26)
Post by hskater26 »
btw. my car looks sexy when i drive at it
Wolfman213
Post by Wolfman213 »
Quote, originally posted by 06pvibe »I wonder why you say that? Halogens= 55w drawHIDs= 35-55w draw. Same-same, no? 55w's is 55w's in my book.When dealing with HIDs vs Halogen, 55w HIDs do need upgraded wiring. It takes a lot more power for that ballast to ignite the bulb and for it to constantly run than a standard 55x halogen bulb. It's not really and apples to apples comparison.
