2009 Vibe base 2.4l Horn Location
Spiff
Post by Spiff » Tue Jun 11, 2019 8:17 pm
Gday
Can someone tell where the horn is located on a 09 Vibe 2.4L base version?
Thanks
Spiff
Re: 2009 Vibe base 2.4l Horn Location
Post by zbyers » Wed Jun 12, 2019 2:52 am
Front crash bar behind the bumper cover. Pop the hood and look down behind the grilles and you will see it.
(2) '03 Bases, '03 GT, '04 AWD, '06 AWD, '07 Base, '09 AWD
GenVibe on Facebook, Everything You Need To Know About Vibes, Great How-To Index
GenVibe Meet 2019
Spiff
Post by Spiff » Thu Jun 13, 2019 3:47 pm
For the life of me I can't find it. Previous owner must have relocated it.
Bookworm
Post by Bookworm » Thu Jun 13, 2019 5:09 pm
Odd. On all of these cars, it's generally between the radiator and the front bumper.
jolt
Post by jolt » Thu Jun 13, 2019 8:53 pm
Attached is a picture of the horn installed. Where the black arrow is pointed is close to the location of the hood latch. The horn bracket is mounted with one bolt to the radiator support. If the horn is not there, check to see if the wire for the horn is still in that area. You may be able to find the horn by tracing the wire back to it if the horn was moved.
Stock horn for 2009 Vibe
Spiff
Post by Spiff » Thu Jun 13, 2019 8:55 pm
Finally found it. It was literally on the bottom of the car driver side right behind the fog light. I had to take the bottom engine cover to get at it.
Thanks
Spiff
Post by zbyers » Fri Jun 14, 2019 2:40 am
I don't think that's where it's usually at. I will look at dad's later to see. It's always been near the hood latch on nearly every modern vehicle I've looked at.
GenVibe Meet 2019
Post by Caretaker » Fri Jun 14, 2019 6:01 am
As things age, "things" tend to start sagging down :o
** 2007 Honda Fit Sport **
jolt
Post by jolt » Sat Jun 15, 2019 9:59 pm
In my 2009, the horn is as pictured above. Do you think someone took the mounting bolt out, dropped the horn, and just just said the heck with it, leaving lay at the bottom? Is the mounting bracket still on it or is it a different/replacement horn?
Post by zbyers » Mon Jun 17, 2019 2:48 am
:lol: :lol:
I checked, it is located as the picture...next to the hood latch.
GenVibe Meet 2019
