Keyed fuse for hardwired dash cam install
utechtl
Post by utechtl »
Hi all,
As the title says i'm looking for a fuse to tap into so that the dash cam is only powered during drives or accessory position. I have the '05 vibe if that makes a difference.
'05 Automatic Base model
Re: Keyed fuse for hardwired dash cam install
The CIG fuse is what I've used for various switched accessories over the years. Hot while on accessory or run.
It's in the uncomfortable-to-access fuse panel under the drivers side of the dash.
Image Image
