All of a sudden I can only get fan to work when I put it to the highest speed (with A/C on, the same).
It's a Pontiac Vibe 2006.
Any ideas what has to be fixed/replaced are greatly appreciated!
Yep, it's a really common issue, and it's an easy thing to fix.gtv237 wrote:Blower motor resistor.
The fans DC motor has flat spots on its windings. The bump knocked it past the flat spot. You need to replace the blower motor.pauleouellette wrote:Fan not working in any position. Moved passenger seat back to rear position and bumped stop and fan started working again in all positions. What?????????
