Blower fan noise
Posted: Tue Nov 06, 2018 7:28 am
by Will1979
There is noise coming from my blower fan. I cleaned the cabin air filter and tried to vacuum in there, but I still have a noise. Also, I noticed a wire that was disconnected. I plugged it back in and the vent above the blow started to continuously close. Any suggestions? Thanks!
Re: Blower fan noise
Posted: Tue Nov 06, 2018 10:34 am
by vibrologist
What is the noise? Tuck-tuck -tuck....?
If it is clicking like that you need a new recirculation actuator. I did this just a few weeks ago.
https://www.youtube.com/watch?v=gjEVPCi5JVU
Posted: Sat Nov 10, 2018 9:55 am
by Will1979
Thank you!
Posted: Mon Nov 19, 2018 12:25 pm
by vfour
Sometimes you get leaves and other debris that ends up in the blower assembly. You need to take it out and clean it or check that the blower isn't cracked.
If you check YouTube there are lots of videos that explain how to do this. Pretty easy.
Posted: Wed Nov 21, 2018 5:11 am
by zbyers
vibrologist wrote:What is the noise? Tuck-tuck -tuck....?
Does it go away or come back when you engage or disengage the circulation button? If so, Vibrologist is spot on.
Otherwise, it could simply be debris in the blower motor. If you haven't changed the cabin air filter in a while, now is as good of a time as any to do so while checking on the motor.
