Hi I have a seized up Cam bolt in my 04 Vibe rear knuckle. Ive hit the thing with a Air chisel, Heat, and penetrating oil. I cannot get the thing out of the bushing. Ive tried looking for a new bushing but the part isn't sold and told i need to buy a new knuckle to get it. However i was wondering if anyone had any ideas on removing the bolt or if there is a way for me to replace that bushing.
They can be tough. You may have to remove the spindle and press it out using a shop press. The other thing that might work is to use a ball joint/U joint press tool to press it out on the car if you have space. Stack spacers to support the bushing and drive the bolt through. The air chisel doesn't work because the bushing just absorbs the impacts. You need the constant steady pressure of the press.
