tpollauf wrote:Well I tried this little trick on my 09 Vibe with the manual transmission and NO LUCK!
Does not work and likely will not work. I still may purchase the OBDII connector to USB and look into online programming stuff. My son's Vibe is now working but then he took it to my friend's shop to have oil changed and some other things done and maybe they solved the problem.
tpollauf, I bought a cable for the OBDII connector from e-bay that came with the software. I just had it hooked up to our '09 Vibe 2.4l auto trans. It works better than the ~$20 scanners you see for sell all over but it is not as good as the full blown factory scanner either. I can change settings for lights, door locks, and those kind of things; so it is not just a reader. It does have two way communication but it is
not fast enough to support live data/graphing transfers. I changed the door locks to unlock when the transmission is put in park, tested it and it works, then I switched it back and tested it again, works like it used too. So, you can toggle settings and read data. It reads my VIN code and has a section to change the VIN code in the ECU. It does far more than just read error codes and for the price, I think it is worth it.
I loaded this on an old laptop with XP. Some people have got this to work with Win7 but is more work to do which is why I kept it simple with XP. Without being hooked up to a car, the software does not show you much and options do not show. The software found my VIN number and year. I just had to pick the model, Matrix. When the software first reads the vehicle, all the ECU's show up in yellow on the laptop screen, which means they did not communicate, but if you click on one of the ECU modules and then go back to the main screen, they all show up as white, which is communicating with the software. I loss communication with the cable when I tried to read live data stream and this is common from what I read with these cheap cables. There is a company that does make a cable/adapter that does work fully with the live data stream but that cable is close to $500.00 so for less than $20.00, it is better than anything else you can buy for that price and does function with the Vibe.
Here is a link to the one I bought on e-bay:
http://www.ebay.com/itm/322216969767?_t ... EBIDX%3AIT
