2004 GT Clutch replaced
tgsnellg75
Post by tgsnellg75 »
Had the clutch replaced last month. 116k miles, car had 86k when I bought it. Bought the exedy OEM kit off of amazon ($100) and had a local mechanic install it for $450. Pays to shop around, quotes from $1200 to $450 (my parts). Just not up to doing it myself. I am an old grandpa, who drives like an old grandma, and I just could not see the need for the heavier duty clutches. The old clutch still had the wear bars on the plate, but was slipping bad on hills and such when in 5th and 6th gear. I had them replace the rear main seal while they were in there. So far so good. Really enjoy the little car.
2004 GT
Re: 2004 GT Clutch replaced
That's a good deal for the install, considering how long it takes. I assume he had a lift and trans jack to make it easier. it took me about 8 or 9 hours on mine, but I had a few issues with the axles on the install.
Good luck and hope it lasts a good long time!
Fatalmasterpiece
Post by Fatalmasterpiece »
OP do you have a link to the clutch kit you bought? I have the same car and am shopping around for a decent clutch.
Fatalmasterpiece wrote:OP do you have a link to the clutch kit you bought? I have the same car and am shopping around for a decent clutch.
Here is the info on the clutch kit and parts I bought for my 03 GT.
viewtopic.php?f=12&t=43780&p=508979
tgsnellg75
EXEDY KTY14 OEM Replacement Clutch Kit
I bought it on Amazon for $107, free shipping.
Seems fine so far, but I do not hot rod around. The local parts houses all want to sell a High performance (More $$) for the GT.
2004 GT
Fatalmasterpiece
Thanks trb and TGSnellg. That clutch looks good and really affordable. I'm still trying to figure out if it's my clutch or the fork/bearing which needs replacing. Fortunately for now I'm close enough to walk to work until I can pull this thing.
circuitsmith
Post by circuitsmith »
I've never seen or heard of a fork failing.
A new release bearing will come with the clutch kit.
2006 Matrix 5-sp
