I've checked and I have not seen any obvious leaks; I haven't seen any puddles under my car. I haven't noticed an excessive amount of smoke either. It was 164,000 miles and is an automatic.Salsa Guy wrote:Have you looked for a coolant leak? Check under the car after running around awhile. First you need to figure out where it's leaking from then come up with a game plan for repair. From the sounds of it your water pump and/or the thermostat is going south. If you had excessive amounts of "smoke" coming out of the tailpipe, after it's been fully warmed up you have some MAJOR issues. But based upon your information it could be any number of things anywhere from a $25 to a $2500 fix. How Many Miles> Auto/Manual? What area of the country you live?
goodvibe77 wrote:I've checked and I have not seen any obvious leaks; I haven't seen any puddles under my car. I haven't noticed an excessive amount of smoke either. It was 164,000 miles and is an automatic.Salsa Guy wrote:Have you looked for a coolant leak? Check under the car after running around awhile. First you need to figure out where it's leaking from then come up with a game plan for repair. From the sounds of it your water pump and/or the thermostat is going south. If you had excessive amounts of "smoke" coming out of the tailpipe, after it's been fully warmed up you have some MAJOR issues. But based upon your information it could be any number of things anywhere from a $25 to a $2500 fix. How Many Miles> Auto/Manual? What area of the country you live?
It would depend on the shop.goodvibe77 wrote:I haven't noticed any wet areas before.Of course today its raining where I live, so there will be some wetness today. I just had the oil changed almost a month ago if it was foamy would they have said something? Also I check the oil before and I did not see any foam coming out.
