Hi Ya'll,
I have an interesting problem with my Ac. The compressor runs even with the Ac switch off (as long as the selector is in the defrost or floor/defrost pos). When the climate selector is in the floor pos the compressor shuts off (unless i press the ac switch). I've unplugged the compressor so my mileage isn't suffering. when I switch to defrost my engine still bumps up in rpm and my engine fan pops on. This, in turn, geeks out the shift points and/or keeps the torque converter spun up. In short it's jerky when coming out of any corner(at pretty much any speed) and pulls at the breaks and surges at stop lights.
The ac clutch and compressor are still good, and the ac switch still works(based on turning the ac on/off when in floor selection). What links the climate selector to the ac clutch? Does anyone know of a good AC electrical dia for the 2005 base model?. It might help me make some sense of this. I've seen hints of ECM issues that have similar symptoms on other posts here on gen vibe. I'm really hoping that isn't the case here. Perhaps one of you has had similar issues and come up with a good fix. If you have any questions or need me to try something let me know.
