Hi Guys, 2009 Vibe owner here.. base model
I ran over a blown out tire on the highway, and it tore up the front underside plastic area pretty good. The bottom grille is gone, and what I think is the water pump plastic cover was jarred loose, along with a bunch of plastic rivets which hold the bumper and other pieces in place, and the temperature sensor wire is just dangling there now.
To me it looked like the entire bottom bumper was still completely in tact.
I know the bottom grille is cheap, so I assumed the repair for this would not be much.. but the insurance adjuster is now telling me that there are some broken end clips on the "tabs" of the front bumper which hold the bottom grille in place, so the entire bumper needs to be replaced.
He has estimated a charge of $748 for all of the work involved with replacing the front bumper, grill, underside plastic damage, painting, and labor..
It was almost a 50/50 split of the above charge between parts/labor.
I wanted to ask you guys this..
1. Is this a rip off for the work that needs to be done? Should i shop this price around? Because it is going to be a headache for me to do so, but if you think the price is a ripoff i will.
2. I know its hard to tell without seeing it, but I am questioning if the entire bumper really needs to be replaced or is there another (less expensive) solution.
I need to decide right away..
thanks guys!
