Oil Pan Drain Plug Gasket: Which one would you use?
Baltovibe
Post by Baltovibe »
I had recently purchased Toyota oil filters from Keithvibe, which included the drain plug gaskets (Toyota 90430-12028). They seem to be made of some type of soft composite material, and is apparently the older style gasket, as pictured:
However, my 2004 Vibe appears to have come with the newer type gasket (Toyota 90430-12031), which I have reused and never replaced. It appears to be a Teflon-coated metal washer, as pictured:
My question is, which washer should I use? The 90430-12028 composite gasket seems to have a history of being destroyed and leaking if overtightened. There is not much info on the 90430-12031 metal gasket failing or otherwise.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse.(Romans 1:19-20)&nbspWhat do you want most in life?
cptnsolo77
Post by cptnsolo77 »
Thats funny, I never knew there was a gasket for the oil or trannmission drain plug. Mine must have fell apart long before I aquired the car LOL. Never had any leaks from either one though.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
bluneon
Post by bluneon »
the composite gasket can only be used once.the aluminum gasket you can reuse, but will need to be replaced every so often. it will flatten out more every time its torqued.these cars come factory installed w the aluminum gasket.
Water boy
Post by Water boy »
HummmmI use a metal gasket that has a rubber inner ring.
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
