Took my Vibe into the dealer because the rear spritzer doesn't spray, it streams. Two jets covering the central quarter of the rear window. No mist, no spray, just a stream. They replaced it, and now it streams in a bit wider pattern, but still jets. Service manager tried the sprayer on a 2009, and same deal: streams. Is this normal?
Yes, very normal. Be glad you do not have an 03. The rear squirter was one stream, no mist. Later changed on 2004 and up to two. I have updated my rear squirter to the two stream part. Makes a big differenece in the winter.
Quote, originally posted by BlueCrush »Welcome to GenVibe!!! Yeah. Mine's more of a dribbler. It has always done it from day 1. I kinda equated it to drooling. I've also upgraded mine to the dual streams as opposed to the single one mine originally had
