Just bought a 2005 VIBE runs good looks ok. I have one problem need to buy a KEY FOB not sure if it's factory installed or dealer installed is there a way to find out? Would like to buy FOB from EBAY...
Have the GM dealership run the VIN and they can tell you if you have it. If you have power locks then more than likely you do. In regards to what flavor Key FOB, I've had issues with some off e-gay, unless they are OEM. Also check for Toyota Matrix Key Fobs. The ones we have work for both 03 Vibe and 05 Matrix.
Try this
If it has power windows, it was probably a factory install. A factory install will also have a hatch glass open switch in the dash, between the steering wheel and the driver door.
Look at the sticker inside the glove box, it will have a bunch of three character codes that indicate what equipment the car had when it left the factory. Look for
AU0 - Remote Entry Lock Control
AU3 - Electric Door Locks
If you see those, then it came from the factory that way.
You should be able to get a fob for a vibe or a matrix, probably others. My 03 Vibe uses a key fob with FCC ID G043VT14T. The matrix fobs will also have a panic button the back, Vibe fobs don't , but the panic button will work on Vibes. The fob I bought off ebay had the panic button, and after setting it off accidentally a few times, I modified the fob to disable the panic button
Great! Next you get to do the programming dance so the car will recognize your new fob in this thread: viewtopic.php?t=1102" onclick="window.open(this.href);return false; See the 6th post. Hopefully you can get it on the first try. It took me a couple of tries before I got it right. Good luck!
