Funny noise when turning off engine..
Ontario
metaxa44
Postby metaxa44 » Sun Apr 26, 2015 4:34 pm
After i changed air filter a month ego i been hearing this funny noise when turning off engine..
Sounds like a big sigh, or air gargling ..
gtv237
Re: Funny noise when turning off engine..
Postby gtv237 » Sun Apr 26, 2015 5:27 pm
Haha "a big sigh"!
I would pop the hood and make sure the airbox it latched tight. it's so easy to accidentally leave one side loose on some cars. Especially if one side hooks and the other side latches.
metaxa44
Postby metaxa44 » Mon Apr 27, 2015 4:21 pm
I did check the air filter box , and everything looks fine..
gtv237
Postby gtv237 » Thu May 07, 2015 6:04 pm
metaxa44 wrote:I did check the air filter box , and everything looks fine..
Maybe the airbox got disconnected from the snorkel assembly in the fender? Follow the intake and see if it's intact. The noise you're hearing is vacuum in the intake manifold escaping through the throttle body. It's perfectly normal. Usually the airbox acts like a muffler so you don't hear it. It definitely sounds like the intake is disconnected somewhere.
Return to “Canada - Ontario”
Who is online
Users browsing this forum: No registered users and 1 guest
