jacking up one side of the car..
Ontario
metaxa44
Post by metaxa44 » Fri Sep 05, 2014 6:13 pm
can You jack up the car in the middle so both tires could be in the air on one side???
Re: jacking up one side of the car..
Post by trb » Fri Sep 05, 2014 7:46 pm
Theoretically, yes, but most of the reinforcement points where you are to place the jack at are right near the wheels, not in the center of the car. But a guy on the Equinox/Terrain forum has a pinch weld jack adapter for his floor jack that he uses to lift up both wheels.
http://www.equinoxforum.net/index.php?topic=5422.0" onclick="window.open(this.href);return false;
Looks like there are several places that sell a version listed in the thread.
FWIW, the scissor jack from my Mustang when extended all the way would raise both tires off the ground. As long as I broke all the lug nuts loose prior to jacking it up, I could rotate the tires that way. A bit shaky, but it worked.
