Windshield wiper blade...
Ontario
metaxa44
Post by metaxa44 » Wed Dec 14, 2011 11:26 am
What most of you do ???Change the whindshield wiper or just the ruber inserts on the 09 Vibe ???Where is the best place to buy it, Toyota ,Canadian Tire ????Does anybody knows the part number???Thanks..
Re: Windshield wiper blade... (metaxa44)
Post by star_deceiver » Wed Dec 14, 2011 12:10 pm
Some Canadian tire stores have the correct size inserts. I believe it's the wide refills.I use different wipers for the winter.
2016 Ram 3500 4x4 Diesel RCLB Dually w/stick
metaxa44
Re: Windshield wiper blade... (star_deceiver)
Post by metaxa44 » Wed Dec 14, 2011 12:21 pm
But do you change the whole wiper or just the refill???
Post by star_deceiver » Wed Dec 14, 2011 12:33 pm
The wipers that came stock with it when I bought it new, I get the refills... but take one into the store with you to compare sizes. There's wide, regular and narrow refills.My winter wipers are the rubber boot kind... can't refill those.
j42.snyder
Post by j42.snyder » Thu Dec 15, 2011 9:14 am
I'm still using the factory wipers, with replacement refills only from Toyota. The fronts are the same as a Matrix, but the rear is 1" shorter.I don't remember the cost on the fronts, but I think the rear was around $6 when I bought it. If our Canadian Tire carries the refills, I've never seen them displayed. Only the narrow ones that are "trim to fit".They're easy to change - only the rubber gets changed. The steel inserts are re-used. Once you do it, you'll find it easy.I've tried different (and some rather expensive) beam type blades in the past, and I never found that any of those would have any advantage over the stock ones. Most didn't last nearly as long, and started chattering much sooner. I know star_deceiver has used the winter boot type blades, but I find they lift off the window too easily at speed with the winds I typically deal with on a daily basis around here. As long as I get any snow off of the wipers before heading out, I've never had any issue with the stock ones. This is my third winter with them so far with no complaints.You could probably get them at a GM dealer too - but I'd expect them to be more costly, and have an inch of dust on them from sitting in the back room for so long.John
metaxa44
Re: (j42.snyder)
Post by metaxa44 » Thu Dec 15, 2011 10:21 am
Thanks ..I will check Toyota tomorrow...
cq358
Post by cq358 » Tue May 22, 2012 4:23 pm
It cost 10 bucks for a driver side refill at local Toyota dealer in Sk.
