Hi Everyone,Our Vibe's have Dexcool ( RED ) in them and it is a surprise for me , because I bet the Matrix does not...Why would they use it in a Toyota engine???Dexcool will get very accidic if you do not change it after 4-5 years , the green thing is not as hard on the system...Did any of you change the antifreeze on your Vibe ???Thanks : Anton
The 09 manual specifies Dexcool, put I'm 99% sure that the factory coolant is Toyota Long Life Antifreeze, which is pink colored. Whoever wrote the GM manual probably copied and pasted a lot.
http://www.globalautoparts.biz....htmlToyota long life is red. Toyota super long life 50/50 pre-diluted (do not add water) is pink. 09-10 vibes and I think all new Toyota's come with the pink stuff now.
Quote, originally posted by 10vibe1.8auto »http://www.globalautoparts.biz....htmlToyota long life is red. Toyota super long life 50/50 pre-diluted (do not add water) is pink. 09-10 vibes and I think all new Toyota's come with the pink stuff now.wow, $22.99+ shipping for a gallon of 50/50? that's crazy. is there another source?
Quote, originally posted by Zimm »wow, $22.99+ shipping for a gallon of 50/50? that's crazy. is there another source?$22.99 for something that you only have to do every 5 years isn't that hard on the pocketbook!I'll be draining some from the rad at some point this year then topping off with some undiluted Red. A 65-35 mix should be sufficient for -46C...
