Air flow directional knob light location and replacement..
Ontario
metaxa44
Post by metaxa44 » Sun Jul 07, 2019 3:34 am
My air flow directional knob was stuck in defrost position and finally I got it to work, but now the light is out..
Where is the bulb location or how do I replace it?
Thanks
Re: Air flow directional knob light location and replacement..
Post by andrewclaus » Sun Jul 07, 2019 5:06 am
This link shows how to disassemble things. Look in Section 71-10.
https://madstyle1972.com/Repair/71/20ikx/x040001.pdf
Post by zbyers » Tue Jul 09, 2019 3:06 am
They suck to remove.
'74 Thing, '79 El Camino, '83 VW Vanagon DoKa '91 Vanagon,
'04 & '06 CRV, (2) '03 Base, '04 GT, '06 AWD, '07 Base, '17 Frontier CCLB
metaxa44
Post by metaxa44 » Tue Jul 09, 2019 5:53 pm
I toke the top trim of and the radio out hoping I can just reach in and change the bulb , but cannot find it...
Post by zbyers » Wed Jul 10, 2019 2:48 am
You will probably need to remove all of the trim around that, including the 12v/110 panel below the HVAC knobs. Not sure if you can reach down inside with the radio removed.
metaxa44
Post by metaxa44 » Sat Jul 20, 2019 2:40 pm
OK , so I got everything apart and it wasn't too bad.
I got the bulb out too and it's burned out..
What is the correct part number for the bulb ?
Wonder how much are they...
By the way radio doesn't have to be disconnected to do the job...
Bookworm
Post by Bookworm » Sun Jul 21, 2019 10:22 am
I don't recall the bulb number - I'm certain another of the forum members will chime in. I suspect it's the same as the ones for the instrument cluster, so a quick search might help, so you can at least compare .
Post by andrewclaus » Sun Jul 21, 2019 5:34 pm
It looks like this is it: https://www.amazon.com/Toyota-90011-010 ... B00TNYMXN6
I use this site to look up part numbers, for future reference: http://www.japan-parts.eu/toyota/us/200 ... uct#55900B
metaxa44
Post by metaxa44 » Sun Jul 21, 2019 7:51 pm
Most likely , except it is yellow ...
Thanks guys...
Post by zbyers » Mon Jul 22, 2019 2:42 am
You could buy a neo3 or neo4 bulb from superbrightleds.com to replace it with an LED one.
metaxa44
Post by metaxa44 » Mon Jul 22, 2019 6:00 am
Ok the job is done ,bulb replaced ..
part # from Toyota 90010-01122 / $ 7..
GM only sells the hole unit and tried to tell me the bulb is hard wired...LOL..
I informed him that is funny because I have the bulb in my hand..
Anyways the local Toyota knew what I am talking about and had it in stock..
Takes 20 minutes to do the job..
Thanks to everyone for the help...
cron
